Old 08-02-2014, 11:47 AM   #1
Slide seal care
I got some 303 Aerospace protectant that I plan to use on the decals and slide seals of my trailer. When you wipe the slide seals do you lightly pull the seals away from the slide and wipe both sides when the slide is out or do you retract the slide and wipe the inside part of the seals then? I ask this because it would be impossible to access the seals for the bed slide once it is retracted because it is so tight when the slide is in. Thanks.
Grey9712 is offline   Reply With Quote
Old 08-02-2014, 12:22 PM   #2
Twisty's Avatar
I just did mine from the outside with the slide out out.
Lift the seal away from the body - spray the back or inside of seal and wipe.
FOR SALE 2014 BOSS 6.2L F350
2012 Surveyor SV264
NW Oregon
Twisty is offline   Reply With Quote
Old 08-02-2014, 01:49 PM   #3
Thanks!
Old 08-02-2014, 04:09 PM   #4
Twisty's Avatar
UR welcome
2012 Surveyor SV264
NW Oregon
slide
