Old 09-14-2008, 01:20 PM   #1
Run Forest Run
Angry Sliding Floor
I was going over the used 2008 Cherokee 30L befor I took it home and as I was pulling the slide in I saw that the left wall as you face the room was lifting up off the floor about 1.5"! I looked under the wall and saw that the four or five screws coming from the wall into the floor had been pulled out of the floor. The dealer said that walking on the floor with the slide in puts alot of force on the floor and thats what caused the floor and wall to fall apart. Has anyone had this happen befor? The dealer said they would fix but I an not sure if i still want the camper even after they fix it.
J.J. King is offline   Reply With Quote
Old 09-14-2008, 02:07 PM   #2
The dealer is right, walking on the slide while it's in does put a lot of strain on it. And yes, I've seen it happen before and it is repairable, just look over it realy close to make sure they did a good job fixing it.
aintgotnun is offline   Reply With Quote
Old 09-14-2008, 04:16 PM   #3
Run Forest Run
Exclamation Slide
Thanks for the feed back. I realy hope this is Camper will hold up as well as the Jayco I am trading in.
Old 09-14-2008, 07:35 PM   #4
Cyber Phrenologist
Radio's Avatar
Hmm? Learn something new everyday.
KU4OJ
Admin at www.openroadsradio.net, part of the Social Knowledge network.
"RVing and Amateur Radio served up on the same plate"
2008 (or is it 2009?) Rockwood 8280SS - 2007 F-150
Radio is offline   Reply With Quote
Old 09-14-2008, 08:59 PM   #5
DRS
Just curious, how does walking on the slide while it is IN put a strain on it? I briefly have to walk on mine frequently to check cabinets before moving the slide in or out and to secure it for travel.
David & Marian
2005 Dodge 2500 Quad Cab Diesel
2008 Rockwood 8280SS FW
DRS is offline   Reply With Quote
Old 09-14-2008, 09:41 PM   #6
Run Forest Run
Slide
The slide floor sits up off the floor of the camper when it is all the way in. There is no support under the slide floor at thet point. It may be diffrent on your camper.
Old 09-14-2008, 11:34 PM   #7
DRS
Okay, that makes sense. My slide does not sit up off the floor when its in. Thanks for the info.
David & Marian
Old 09-15-2008, 05:13 AM   #8
Have to keep this in mine, your right Radio we learn something new every day.
