Old 10-28-2011, 11:55 AM   #1
RollingDownTheHighway's Avatar
snow coming - not winterized?
I haven't winterized my camper yet and this weekend they're calling for up to 10" of snow. I'm scheduled to take it in tomorrow to get it done, but I'm not a HUGE fan of towing a camper in 30+ mph winds with higher gusts. So I'm not sure if I'll be able to make it. What can I do to it so nothing freezes in it? It's an '11 and we used it twice this summer and I drained everything but its not winterized. This is the first real cold weather we had with last night getting down to 33, but with the snow coming, and then 50 on sunday, is there anything I can do until I get it winterized?
RollingDownTheHighway is offline   Reply With Quote
Old 10-28-2011, 12:05 PM   #2
TURBS's Avatar
At minimum pour rv antifreeze down the drains and in toilet.
TURBS is online now   Reply With Quote
Old 10-28-2011, 12:56 PM   #3
3 Happy Campers's Avatar
If you have already drained the lines via the low point drains then your 75% there. If you have access to an air compressor you can blow out the lines to make sure all remaining water in any low spots is gone.
Adjust the output pressure to about 20-30 psi.
Remove the hot water heater plug & drain that.
Go inside & open all the faucets. (Leave open)
Faucets will freeze & the seats will distort & once thawed will leak.
By opening the faucet you leave room for expansion of the internal parts.
I use my 5er right to the end of Dec.
I do the above after each trip from Oct to Dec.
Have never had a problem in 20 years.
Dave, Judy & Daisy May
Perkasie, PA
2010 Sierra 356RL
2011 Silverado 2500 4WD, LT, Ext Cab, LB
Duramax 6.6L V8 Turbo Diesel
Allison 1000 6-Speed Automatic Transmission
3 Happy Campers is offline   Reply With Quote
Old 10-28-2011, 12:57 PM   #4
Triguy's Avatar
If you can't complete the process with AF or blowing it out, then open the faucets. This might help alleviate some of the pressure built up if a little bit of water freezes in a low point.
Also, remember that the PEX tubing has a tendency to flex a little bit. This doesn't make it burst proof; but it helps.
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 10-28-2011, 01:04 PM   #5
Dodge Guy's Avatar
Just because it snows doesn`t meen it will freeze hard enough to do damage. if it is only 32 overnite then I wouldn`t worry, especially if you drained the lines. when it gets down to the 20`s for days straight then it`s time to worry!
02 Ford Excursion V-10 4.30 gears 5 Star Tuner Y-pipe mod Hellwig sway bar Rear Airbags
Prodigy and Dual Cam
07 Cherokee 32B
Better to have a bad day of camping than a good day at work!
Dodge Guy is offline   Reply With Quote
Old 10-28-2011, 01:23 PM   #6
Labzy's Avatar
2010 Dodge Ram 1500
2012 Rockwood 2306
DH (Alan), DD (Madison) and Zoey the lab,
Labzy is offline   Reply With Quote
Old 11-10-2011, 04:12 PM   #7
update: I was able to get it winterized that Saturday the day the storm hit and we lost power for a week.
