Old 10-05-2007, 05:28 PM   #11
In the last pic..... Is that the previous mounting point for your scissor jacks? How far from the rear of the trailer are they?
aintgotnun is offline   Reply With Quote
Old 10-05-2007, 09:37 PM   #12
powerboatr's Avatar
about a foot
the rear fiberglass cap hangs down about the same height
casters may be a serious solution
i just wish i knew 100% where i touched bottom
i think it was at the feed store when i got her weighed for texas plates
Living in the Piney Woods of Texas.
powerboatr is offline   Reply With Quote
Old 10-05-2007, 09:54 PM   #13
well heck then those same casters that I mounted on mine should work for you as well. doesn't look like any plastic is in the way so it would make for a nice quick job
Old 10-05-2007, 10:05 PM   #14
powerboatr's Avatar
what size caster?
i seen some 4" ers in the camping book, but need to go to hootens and see what they have.
Old 10-06-2007, 07:34 PM   #15
the one's that I installed are about 4" and are straight on (don't swivel)
they are pretty heavy duty and I believe they could take a beating
got'em at camping world for around $30 each
Old 10-06-2007, 09:37 PM   #16
powerboatr's Avatar
i found some at hootens (rednecks homedepot and lowes, if its not at hootens it just doesnt exist)
anywho 5 bix each for a 4" steel rubber cased 10k rated greaseable needle bearing non swivel wheel
got tw. painted em black and will install in the am...pics to follow
Old 10-07-2007, 10:45 AM   #17
budfans's Avatar
if you don't have scissor jacks on the back what do you have ??
07 285B+ cherokee 5er
02 F350 power stroke c/c
budfans is offline   Reply With Quote
Old 10-07-2007, 10:47 AM   #18
budfans's Avatar
never mind I went back and looked at the pics you still have them !!
Old 10-07-2007, 03:21 PM   #19
powerboatr's Avatar
I moved the scissors forward about 6 feet closer to the rear wheels.
two reasons, lots of site we pull in or back on are short on the paved or packed surface and the tail hangs out
second the closer to the rear wheels reduces the frame BOW when we sit for long periods, i run alot of weight off the tires when we are parked.
i enclosed the pics of the new wheels
they are inexspensive enough if i tweak one it aint no big deal. plus they dont hang any lower than the original rear stabilizer jacks
and one bonus of us at roosevelt state park in mississippi where you can tell the long overhang would make it difficult to stabilize
ID:	412   Click image for larger version
ID:	413   Click image for larger version
Old 10-08-2007, 06:53 AM   #20
Nice!
The reason I didn't go with rubber casters is if I drag while turning then they would "tweak". But like you said, $5 is pretty cheap. And I didn't even think to look at a hardware store. DOH!
Saturday the 27th we've got stuff going on but Sunday the 28th is open for us. Like I said if you wanna park for the night you are more than welcome.
greg
5th wheel
