05-05-2013, 02:00 PM
Take The Road Less Travld
Stablizing the Roo
Ok, playing with my new 2013 Roo. When I have the stablizing jacks down and a chock on the tires, the trailer is still rocky. You walk from one side to the other or even shack your booty the trailer rocks. My popup never rocked so much in fact it was pretty solid and the dealer did not explain to me really how to stabilize it much. The book says some models came with an Ebreak but I can't find one. Any ideas or suggestions from current Roo owners?
"Take The Road Less Traveled"
2020 Cherokee 294BH
2021 Chevy Silverado 2500HD 6.6 Duramax Diesel
I've been an RVer since 2007, Lifetime Camper
Gotta love the Outdoors, Disconnect and Enjoy Nature!
05-05-2013, 02:09 PM
Engineer of Crazy Train
I got a set of X-chocks from Amazon and they are aMAZing. What you can do, when you chock up, put the back chocks down, drive onto them just a bit, and have someone put the front ones on. That could help you, also.
TV - 2015 Ram Truck EcoDiesel
TT - 2015 Rockwood Roo 183 (SOLD due to 2 years off work)
Locomotive Engineer
Nights Camping --- 2015 - 19 Camped | Winterized -- 2014 - 18
Come read my Camping Blogs
05-05-2013, 02:14 PM
x2 on the X-Chocks. The chocks that I use are BAL 28012 X-Chock Tire Locking Chock. $78 for a pair at Amazon
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
05-05-2013, 04:16 PM
Always Learning
Same idea, different brand - RotoChoks.
As well, can you use a product like JT's StrongArms or SteadyFast or UltraFab Eliminators? It's another way of firming stuff up.
05-05-2013, 04:43 PM
So I need to find a way to lock the tires basically?
2020 Cherokee 294BH
05-05-2013, 05:21 PM
Always Learning
That's a start, yes.
05-05-2013, 05:35 PM
Maybe I need to crank the stabilizers a little higher. How do you know if its too high other than the tires are off the ground?
2020 Cherokee 294BH
05-05-2013, 05:49 PM
Always Learning
Generally, you don't want to lift the camper by the stabilizers at all. It can twist the frame and you'll know because doors can get hard to open/close.
You want them snug. I would hit ground and then give my pop-up camper's stabilizers a little push and leave it at that. Same idea with stabilizers on bigger campers.
To get the movement out- you really need between the wheel chocks and you need to add triangulating stabilizers mounted to your stabilizers. Then, depending on if you still have movement- extra stabilizer jacks near the axles are supposed to help (my 42' fifth wheel still moves a good bit after both of the above).
