Old 08-23-2015, 07:14 AM   #1
burch42's Avatar
Stink from under the sink area
Anyone out there know why or what could be causing a stink from under the sink area? I checked pipes nothing loose and no leaks. We are in the middle of a trip.
The stink is really bad when you open the cupboard door.
Any help would be great
burch42 is offline   Reply With Quote
Old 08-23-2015, 07:31 AM   #2
B and B's Avatar
Air admittance valve. Look up really high in the cabinet, attached to black abs drain pipe. They unscrew easy to either un jam or replace.
B and B
Old 08-23-2015, 07:33 AM   #3
fonzie's Avatar
X2
Fonzie
Old 08-23-2015, 07:57 AM   #4
burch42's Avatar
So do I just unscrew it and run some water or do I need to do something else?
Old 08-23-2015, 08:36 AM   #5
Unscrew it and just clean the rubber diaphram inside if it is not damaged. Diaphram is quit flimsy so be careful. I believe some lubricate it will a very small amount of something like cooking oil.
dmac1951 is offline   Reply With Quote
Old 08-23-2015, 08:47 AM   #6
BombDoc's Avatar
This happened to me at the Nashville rally. DW noticed it and asked me to investigate. Sure enough as soon as you opened the cabinet door, foul smell!! I located the device described above but could not get it to either unscrew or come off the pipe. It seemed to free spin without coming off. So, I twisted it around a couple times and the smell went away. Didn't have an issue the rest of the trip. Hope this helps.
John & April & "Scout"
2013 Sabre 32RCTS-6
Nights Camped 2013-(44) 2014-(59) 2015-(47)
2016-(32) 2017-(13) 2018-(20) 2019-0
BombDoc is offline   Reply With Quote
Old 08-23-2015, 08:53 AM   #7
burch42's Avatar
Thanks for the replies, I took the cap right off and ran some water. Went to the Epcot centre so we will know when we get back if it worked. I saw the white cap inside the black one. Nothing on it very clean, is there another one inside the tube?
Old 08-23-2015, 09:11 AM   #8
fonzie's Avatar
No nothing inside the pipe. If it still smell you can replace it. Home Depot carry them.
Oatey 1-1/2 in. ABS PTC In-Line Cheater Vent-39012 - The Home Depot
Fonzie
Old 08-23-2015, 09:45 AM   #9
burch42's Avatar
Thanks for all the help, I will check after we get back from the park.
Old 08-23-2015, 11:27 AM   #10
B and B's Avatar
Are you sure the foul smell was not from the camper next door...
Old 08-23-2015, 11:46 AM   #11
Witch Doctor's Avatar
I always dump some chemical down in the tank, they make one for odors or you can just use what you use in the head. You have to remember that sometimes food particles or grease will get in the tank, haven't had a problem since. Also could be that valve, mine wasn't...
Coachmen M/H
Concord
2018 / 300 DSC
Old 08-23-2015, 11:58 AM   #12
Grn_Mtns's Avatar
Our galley tank will smell when it gets close to full. After we drain it the smell stops.
Best,
Grn_Mtns
____________________________________
2018 8329 SS Rockwood /260watts solar
Grn_Mtns is offline   Reply With Quote
Old 08-23-2015, 12:46 PM   #13
I just changed the part under the sink in my Georgetown. When I took the bad one back to dealer somehow glue got on diaphragm and it didn't work. New one is working fine. No order so a happy wife a happy life
cubsandcoltsfan is offline   Reply With Quote
Old 08-23-2015, 01:55 PM   #14
Medic44's Avatar
So funny, my wife just noticed ours last night, thanks for the information it fixed ours.
Medic44 is offline   Reply With Quote
Old 08-24-2015, 07:35 AM   #15
Wolverine 1945's Avatar
Did B&B mean cabinet next door ???
LOL !!!
Wolverine 1945 is offline   Reply With Quote
Old 08-24-2015, 07:39 AM   #16
I always use Gray water deodorizer !!!
Old 08-24-2015, 12:25 PM   #17
burch42's Avatar
I put some chems down the drain and twisting the cap seems to have helped.
Thanks very much for the responses. This forum truly is a help!
Old 08-25-2015, 02:57 PM   #18
Cummins Retired
After reading the posts, I checked the drain caps on my camper and have the black ones referenced. Neither one was screwed all the way down, only about half way. Should they be hand tightened or left loose about halfway up?? My mind tells me tightened, but not sure here.
2010 RAM 2500 w/Cummins Diesel, 4.10 axle
2020 Rockwood Ultra-Lite 2650WS 5th Wheel
tommybill is offline   Reply With Quote
