Old 08-23-2015, 07:14 AM   #1
burch42's Avatar
Stink from under the sink area
Anyone out there know why or what could be causing a stink from under the sink area? I checked pipes nothing loose and no leaks. We are in the middle of a trip.
The stink is really bad when you open the cupboard door.
Any help would be great
burch42 is offline   Reply With Quote
Old 08-23-2015, 07:31 AM   #2
B and B's Avatar
Air admittance valve. Look up really high in the cabinet, attached to black abs drain pipe. They unscrew easy to either un jam or replace.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 08-23-2015, 07:33 AM   #3
fonzie's Avatar
X2
Fonzie
Old 08-23-2015, 07:57 AM   #4
burch42's Avatar
So do I just unscrew it and run some water or do I need to do something else?
Old 08-23-2015, 08:36 AM   #5
Unscrew it and just clean the rubber diaphram inside if it is not damaged. Diaphram is quit flimsy so be careful. I believe some lubricate it will a very small amount of something like cooking oil.
dmac1951 is offline   Reply With Quote
Old 08-23-2015, 08:47 AM   #6
BombDoc's Avatar
This happened to me at the Nashville rally. DW noticed it and asked me to investigate. Sure enough as soon as you opened the cabinet door, foul smell!! I located the device described above but could not get it to either unscrew or come off the pipe. It seemed to free spin without coming off. So, I twisted it around a couple times and the smell went away. Didn't have an issue the rest of the trip. Hope this helps.
John & April & "Scout"
2013 Sabre 32RCTS-6
Nights Camped 2013-(44) 2014-(59) 2015-(47)
2016-(32) 2017-(13) 2018-0
BombDoc is online now   Reply With Quote
Old 08-23-2015, 08:53 AM   #7
burch42's Avatar
Thanks for the replies, I took the cap right off and ran some water. Went to the Epcot centre so we will know when we get back if it worked. I saw the white cap inside the black one. Nothing on it very clean, is there another one inside the tube?
Old 08-23-2015, 09:11 AM   #8
fonzie's Avatar
No nothing inside the pipe. If it still smell you can replace it. Home Depot carry them.
Oatey 1-1/2 in. ABS PTC In-Line Cheater Vent-39012 - The Home Depot
Fonzie
Old 08-23-2015, 09:45 AM   #9
burch42's Avatar
Thanks for all the help, I will check after we get back from the park.
Old 08-23-2015, 11:27 AM   #10
B and B's Avatar
Are you sure the foul smell was not from the camper next door...
