Old 09-15-2018, 08:18 AM   #1
swapping wall plugs
So i would like to swap out a couple wall plugs in the 5'er. i want to put the ones with USB's in. are the plugs in campers the same as household?
thanks
2018 Puma Unleashed 373 QSI Toy hauler Fifth wheel
Firedude26 is offline   Reply With Quote
Old 09-15-2018, 08:26 AM   #2
A32Deuce's Avatar
They are thinner then what is in a house. Not all walls are thick enough. That's how it is in mine. Went through one wall into a cabinet in the bathroom for enough depth.
Had to change the wall box also.
A32Deuce is offline   Reply With Quote
Old 09-15-2018, 08:28 AM   #3
Some are but very few, most are thin press to gather units,that have No separate wall box! If your wall is thick enough change to household shallow box!Youroo! !
Old 09-15-2018, 08:49 AM   #4
I bought a plug in adapter that just plugs on top of an outlet and provides two 120 volt outlets and two Uses. No rewiring required.
Cedar Creek Lake, Texas
2017 Wildwood 27 RLSS
2016 Ram 5.7L crewcab, 8 speed transmission
CedarCreekWoody is online now   Reply With Quote
Old 09-15-2018, 09:09 AM   #5
do u happen to know where?
Old 09-15-2018, 09:12 AM   #6
They are available everywhere.
I've seen them at Walmart, Lowe's, Home Depot, Menards, Ace and a Google search brought up more choices than I had time to browse.
https://www.google.com/search?ei=zRO...10.rbIdQrSLcOs
Days Camped: '16=46 '17=30 '18=51 '19=53
Old 09-15-2018, 10:31 AM   #7
I bought it locally, most likely Lowes or Wal-Mart. Similar item is on Amazon.
Old 09-15-2018, 11:20 AM   #8
Jim34RL's Avatar
I use a Power Cube that has three 110/120V outlets and a two YSB ports in the cube. These were purchased from Lee Valley. com see attached link. They are also surge protected which to me was want I wanted.
PowerCubeâ„¢ Multi-Outlets - Lee Valley Tools
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 135K+miles
Old 09-15-2018, 01:54 PM   #9
K2Kevin's Avatar
I’ve looked for the same thing, I haven’t found anything narrow enough for my walls without really jamming it in, and it still may not fit comfortably. I have seen those add on plugs, which looks like a great option. I have usb all over my camper, but would be nice to have at each outlet as well.
K2Kevin is offline   Reply With Quote
Old 09-15-2018, 02:13 PM   #10
Senior Member - Retired
I also want to change out a couple of outlets to outlets that can provide AC as well as USB connections to charge phones, tablets, etc. The GFI breaker/outlet in our MH bathroom is installed in a shallow wall and to make it fit there is white bezel and wall plate that enables the GFI to stick out from the wall one inch.
Wonder if this idea could be adopted for use for shallow outlets such as shown in this link https://www.easternmarine.com/single...h-spacer-13505
John & Gloria Hunsaker FROG Member CA-0030-988
2014 Georgetown XL 334QS (class A with 4 slides)
2013 Smart Car TOAD
Blue Ox Aventa LX tow bar, base plates, diode kit
SMI Stay-IN-Play Duo auxiliary braking system
25' Off shore blue water fishing boat
CA Fisherman is online now   Reply With Quote
Old 09-15-2018, 03:10 PM   #11
A32Deuce's Avatar
Yes if you can get them.
