I'm relatively happy. I think it's a little expensive for what you get.
I had one camera DOA right of the box. Naturally I had to pay to ship it back to them so they could test it and send me another. Good customer service would have been to pay shipping once they found it bad. Especially on a DOA unit. If it had worked and then quit, that's one thing, but DOA is another.
I have two cameras, One is mounted on the back of the pickup and it works fine. The other is mounted on the back of the RV at the vent hood outlet. I had to add a high gain antenna and move it up above the top of the wall on the roof to get it to work reliably. Keep in mind that we have an aluminum walled RV, so that contributed to the issue. Once I moved the antenna above the wall it works pretty well with few drop-outs.
I've looked at cheaper units and they look exactly the same and have the same specs as the Tadibrothers. Makes you wonder if the cheaper ones would work just as well?
If I had it to do aver again, I'd probably buy one of the cheaper units on Amazon with a good return policy and try it out before I bought the TadiBrothers.
Gotta go campin!
