Old 10-09-2006, 08:55 PM   #1
Tank Heaters
I have just purchased our first travel trailer. We got a Rockwood 2601. It came with a tank heater. Here is my question: Does the tank work on all tanks, including the black and gray tanks? If the heater does work in those tanks, does there need to be anything in those tanks if you run the tank heaters? I am concerned that if the tanks are empty, the heater will damage the tank.
moogle2002 is offline   Reply With Quote
Old 10-09-2006, 10:50 PM   #2
Bear's Avatar
You should have tank heater pads on all tanks and heat wraps on all lines. No you will not hurt your tanks with them on if empty. They have a temp sensor on them, they won't even turn on (even with the switch on) untill temp is 2deg. below freezing.
Cheers
Bear
2000 Volvo 660 D12 425 hp 1550 torque 15 speed, Trailer Saver air ride hitch. 2006 Canadian Sport 385 RLTS 40'10" triple slide, triple axle 5'er toybox, 300 watts solar, 3000 watt inverter, Onan 5500 Marques Platnum. 1998 Polaris 300 Explorer 4X4 quad, 2003 Polaris 700 Sportsman 4X4 quad, 1994 Jeep YJ "TOAD" 3" lift 31" ProComp Mud Terrain tires
https://community.webshots.com/user/Bears319
https://www.picturetrail.com/bears319
Mission Statement : ZZZZzzzzz
Bear is offline   Reply With Quote
Old 10-17-2006, 01:03 PM   #3
2manytoyz's Avatar
I have that option on our new TT. It arrived yesterday, and while climbing underneath, I can see the heater pads adhered to the underside of my black and grey tanks. Didn't get a chance yet to check the fresh water tank, but sure it's there too.
That's a good tip about them not coming on until the sensor detects enough of a temperature drop. One thing I plan on changing is the switch for my tank heater. It's on the cabinet beside the couch. No doubt it will be accidently turned on. I still plan on putting in a guarded switch. Even the indicator light will run the battery down over time.
Robert & Dawn
2015 Forest River Georgetown 328TS
2006 Jeep Wrangler Unlimited TOAD
https://www.2manytoyz.com/
2manytoyz is offline   Reply With Quote
Old 10-20-2006, 03:43 PM   #4
2manytoyz's Avatar
Update, took a look at my tank heaters today
Had to work early today, so took off early. Ended up stopping by the camper (couldn't help myself!).
Here's a picture of the heater pads adhered to the bottom of both the grey and black tanks, as well as wrapped around the dump lines (look on the drain line at the left edge of the picture).
The brand name on these is Ultra Heat Inc. Their website is located here: http://www.ultraheat.com/ducted_vs_ultraheat.html
Details gleaned from their website:
TESTED TO: Minus - 11° F (-24° C) Cold Room
Power Switch "ON" OR "OFF." Tank Heaters turned on will automatically operate with Thermostat Control:
On at 44° F (+ 7° C)
Off at 64° F (+18° C)
Robert & Dawn
Similar Threads
Thread Thread Starter Forum Replies Last Post
Anyone Know How to Drain the Fresh Water Georgetown370 General Community Discussions 10 12-28-2006 04:48 PM
