Old 07-28-2019, 07:46 PM   #1
Tear in Vinyl Flooring
I have a tear in my tear in my Vinyl Flooring. Is this repairable? How would you replace, seems like all one continuous sheet of vinyl.
Keith3679 is offline   Reply With Quote
Old 07-29-2019, 12:38 AM   #2
I had a tear in mine and was able to fix it. I was able to buy a piece of vinyl that matched my floor from Rockwood and cut out a section to match and replace. As long as you follow the "grout" line it's pretty easy. Here are some links showing how.
https://www.google.com/url?sa=t&sour...76SyLjBzw9Qwg3
https://www.diynetwork.com/how-to/ro...vinyl-flooring
https://www.todayshomeowner.com/vide...inyl-flooring/
dnmatt7 is offline   Reply With Quote
Old 07-29-2019, 04:44 AM   #3
Where did you purchase the replacement vinyl?
Old 07-29-2019, 07:12 AM   #4
I repaired mine with wood glue underneath and crazy glue on the edges. Holding up well after > 1 year. It's not perfect, but fast and easy. The pattern of the vinyl makes it hard to notice unless you're looking for it.
Skip12 is offline   Reply With Quote
Old 07-29-2019, 08:25 AM   #5
I called Rockwood and gave them my VIN and a picture of the vinyl. It wasn't cheap but worth it to match so well. You can't tell where I replaced.
Old 07-29-2019, 01:47 PM   #6
I had a six inch tear in the center of the floor. about 1/2 inch wide and six inches long. Living near Houston tx in the winter I just did a search for vinyl repair on the internet. I hired a lady expert She arrived the next day and repaired the hole blending in the colors by hand. Great job total cost less than $200.
tooclose is offline   Reply With Quote
Old 07-29-2019, 01:59 PM   #7
AKA: 'tiredTeacher
awellis3's Avatar
Which phone number produced the wanted result? I have to replace a section torn by a screw backing down from my slide's frame. It's an ugly tear.
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
awellis3 is offline   Reply With Quote
Old 07-29-2019, 02:13 PM   #8
Was
This is the way to fix it. You may be able to cut a piece of vinyl from a spot that is never or almost never seen for the repair, like under or inside a cabinet, or under an appliance, if you cannot find the match.
Was is offline   Reply With Quote
Old 07-29-2019, 04:37 PM   #9
Final Flooring repair
We had a rip in our final floor from a repair while at FROG Rally in Goshen. They brought out a person who repaired it perfectly so a repair is possible. I would check with local car dealers to see who they use.
safrog is offline   Reply With Quote
Old 07-29-2019, 05:17 PM   #10
Last year I dealt with Brooke Madden for the vinyl. It was $16 per linear foot (8 feet wide). I went ahead and got 2 feet to ensure I could pattern match. When they sent it to me it was almost twice what I asked for and it turns out what i needed was right at the edge so i have a lot as spare.
Brooke Madden
Parts Coordinator
Forest River / Millersburg, IN
Rockwood/Flagstaff Divisions
Office (574)-642-8926
Email: bmadden@forestriverinc.com
Old 07-31-2019, 10:26 AM   #11
We had a tear in ours. The floor was an ugly pattern anyway. We fixed it by laying lifeprrof laminate flooring in the camper. Looks way better. It added a little bit of weight. Maybe 150lbs but the look is worth the weight.
Bbouch84 is offline   Reply With Quote
floor, flooring
