Old 07-08-2014, 09:00 PM   #1
burch42's Avatar
Television or Cable in TT
Hey All, just a question with our television in our TT. We took the TT out for our first trip and i raised the antenna and did the channel search on the tv and the search did not find any channels. My question is, is there some sort of attachment that i need? or is there another function that i need to do to find the local channels?
my TT is a 2014 Apex 288 BHS
burch42 is offline   Reply With Quote
Old 07-08-2014, 09:06 PM   #2
Toby's Avatar
Does your trailer have that little button at the outlet that amplifies the antenna signal? I have to push that little guy in for the antenna to work. You're might be different than mine though as mine doesn't raise either.
2018 Ford F250
2019 Arctic Wolf F295QSL8
Toby is offline   Reply With Quote
Old 07-08-2014, 09:12 PM   #3
burch42's Avatar
im not sure, ill have to look. where would the button be?
Old 07-08-2014, 09:14 PM   #4
heavynlori's Avatar
Make sure TV is set to air or antenna before starting channel scan too
heavynlori is online now   Reply With Quote
Old 07-08-2014, 09:16 PM   #5
heavynlori's Avatar
Button is right next to hookup panel - very small hard to find - might be black button and turns on a small red or green LED light when on
Old 07-08-2014, 09:45 PM   #6
dcheatwood's Avatar
It will be where your TV, either main TV or more often, bedroom TV cable screws into the wall or ceiling.
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
Old 07-08-2014, 09:49 PM   #7
WFD
Also very much depends where you are...there are several parks we go to where we can't get any channels, and others where all we get has very poor reception...its hit and miss.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 07-08-2014, 09:50 PM   #8
Coops1's Avatar
Check in the cupboard underneath your TV, thats where mine is.
26WRB - V-Lite
Denali HD LML
Coops1 is offline   Reply With Quote
Old 07-08-2014, 09:51 PM   #9
Wayne & Kim
Wayne & Kimmy's Avatar
Might be located inside a cabinet near where the main TV/entertainment center is located. If light is on it will be in the antenna boost mode. If you hook up to cable be sure to press button to turn it off or you will likely get bad reception.
Wayne
Wayne and Kim
2014 Cedar Creek 36CKTS
2011 Ford F250 King Ranch 4x2 Diesel, added springs
Nights camped: 2014 - 32; 2013 - 23
Wayne & Kimmy is offline   Reply With Quote
Old 07-08-2014, 09:52 PM   #10
dcheatwood's Avatar
May look like one of these. Tiny black button will press in and out turning booster on when light comes on.
television
