Old 01-19-2015, 04:05 PM   #1
Vpierce's Avatar
Thinking about trading
My husband and I went to the RV show and we're thinking of trading our FBRS 21 micro lite for a 8524 RLWS super lite. Can anyone give info about what you tow with and the type of mileage? Hubby wants to know all about it. We tow with 1500 crew cab Silverado. Anyone have this 5th wheel? How do you like it?
Vpierce is offline   Reply With Quote
Old 01-19-2015, 04:06 PM   #2
TURBS's Avatar
What's the specs on the camper and what's the spec on your truck?
We need more info!
Year make model
Payload gvw pin weight etc etc
Old 01-19-2015, 04:10 PM   #3
PSUFan1's Avatar
Oh no, people on this forum are going to have a field day with a 5th wheel towed by a 1/2 ton.
Payload will be your primary issue with that setup.
Tim & Tracy, Jennifer (15), Alyssa (10), our dog Jazy
2012 Ford F150 EB Crew FX4 3.73 gears
2017 Grand Design Imagine 2800BH
Previous: 2012 Flagstaff MicroLite 23LB
2006 GMC Envoy Denali V8 & 2005 GMC Envoy I6
PSUFan1 is offline   Reply With Quote
Old 01-23-2015, 09:32 PM   #4
Ksilvi's Avatar
Yea, on here, you're gonna get advice that you should only be pulling a pop-up with that truck. It's diesel dually to pull anything more than a pop-up or you're doomed for sure.
2014 Crusader 295rst
2014 F150 Fx4
2017 Cherokee Wolf Pup 17rp
2017 F-150 FX2 Sport
Ksilvi is offline   Reply With Quote
Old 01-23-2015, 09:53 PM   #5
Fulltime family RVer
It looks like it has a dry pin weight of 1,181 pounds best guess, with a cargo carrying capacity of 1,450 pounds, you'll likely be running close to the camper's gross weight (8,050 pounds) after options are added, you're carrying full propane, a battery and your self. That should give you a loaded pin weight of 1,400-1,600 pounds.
You need to check your truck's available payload and determine if you'll be within that once you add in a hitch, yourself and hubby, stuff in/on the truck, and the camper's pin weight. If not, you have to make an educated decision if you're willing to exceed it's published sticker weights.
Camper specs:
http://www.forestriverinc.com/produc...delID=719#Main
How I calculated loaded pin weights:
http://towingplanner.com/Estimators/...92&lw=8050&a=2
ependydad is online now   Reply With Quote
