Old 04-16-2015, 09:42 AM   #11
Are these (16") tires? G rated tires on a (Lite Trailer pulled by a F 150 seems like (Total Overkill)! Youroo!!
youroo is online now   Reply With Quote
Old 04-16-2015, 09:45 AM   #12
Learjet's Avatar
The other consideration, esp if you run the tires at higher pressure, how rough will that ride be on your trailer and frame?
-2017 Ram Cummins, Aisin DRW 3.73, 4x4
-2015 Wildcat 317RL
-B&W Companion , MorRyde pinbox
Learjet is offline   Reply With Quote
Old 04-16-2015, 12:11 PM   #13
G rated tires
Discount Tires Direct sell these for $140.00 each.
Taskmaster Provider ST Radial F385 Trailer Tire
ST235 /85 R16 129L G RBL
mb1834 is offline   Reply With Quote
Old 04-16-2015, 12:31 PM   #14
Tires
I would go to a Goodyear fleet dealer and get a price, also I usually make at least 10 phone calls to dealers to get the best price
Docgeo is offline   Reply With Quote
Old 04-16-2015, 12:46 PM   #15
Not nearly the damage a blown tire from running lower pressure would cause. Put shocks on the trailer and you don't have to worry about it.
Old 04-16-2015, 12:51 PM   #16
I don't think there is any overkill as far as tires go, these are the same size you mentioned 215 85 R16 and I think they are probably cheaper
Old 04-16-2015, 01:05 PM   #17
BamaBob's Avatar
One word of caution...I notice where the tire dealer was going to put LT tires on your rig.
Search the forums for the extended debate on LT vs ST tires. I and several (many? ) others do not recommend or would use a LT tire on a multi-axel trailer. Bottom Line is the ST tire has a beefed-up sidewall that can handle the axel movements the LT tire is not designed for.
Like others I suggest Goodyear Marathons or Maxxis - neck and neck in reputation and quality.
Nights Camped: 2013 - 242014 - 422015 - 56Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 04-17-2015, 10:23 AM   #18
Tire issues
Be careful about tire load ratings. Spending more for a tire with higher ply rating may be a waste of money for you. A tire with higher ply rating simply means that it is designed to hold more air pressure. Higher air pressure means more load carrying capacity. Most people don't know that the wheel that the tire is mounted on also has a maximum allowable air pressure. Max air pressure is stamped on the wheel. Do not buy tires that require more air then the wheel is capable of holding. Wheels can blow apart to if overloaded.
Tireguy397 is offline   Reply With Quote
tire
