Old 04-04-2015, 08:12 PM   #21
GreenImp's Avatar
Send a message via MSN to GreenImp
Nothing wrong with Amazon, but they are only 97.70 at OnlineTires.com (plus shipping). I would figure out shipping to your place and then visit your local Discount Tire store for a price match attempt.
https://www.onlinetires.com/products...+113q+bsw.html
'04 GMC Sierra 2500HD, CCSB, D/A, MaxBrake, B&W Companion, Retrax Pro, AR Power Steps
2013 Rockwood 8289WS w/Diamond pkg
1969 Camaro RS/SS Convertible
Dad's old 1968 Empi Imp (recently recovered from under 21 years worth of boxes/dust)
GreenImp is offline   Reply With Quote
Old 04-04-2015, 08:30 PM   #22
I was just using Amazon to show the type of tire. I actually stopped at Discount Tire today and for those in the link, they said they would be $595. I will have to see how much they would be from OnlineTires.com with shipping. Thanks!
Grey9712 is offline   Reply With Quote
Old 04-05-2015, 07:43 AM   #23
Ddubya's Avatar
The Discount Tire near me has Carlisle 15 inch load range E1 speed rating N for $109.00.
Anyone have experience with these
Ddubya is offline   Reply With Quote
Old 05-01-2015, 07:24 PM   #24
I ended up getting Maxxis tires. When I got the rims put on, the pressure they filled the tires to was 45 psi. The max pressure of the tire is 65. How much pressure do you guys put in yours?
Old 05-01-2015, 07:27 PM   #25
Ford Idaho's Avatar
What it says on the sidewall, IMO anything less is under inflation.
Under inflation bad, very bad!
Old 05-01-2015, 11:43 PM   #26
GreenImp's Avatar
There is most likely a sticker on the front/side of your trailer that states the minimum PSI. The tires sidewall will state the Maximum PSI. As long as you are anywhere between those, you are good. If you don't have the sticker on the side, you can use this chart to determine your minimum PSI, but you would need to know your axle weights.
Trailer Tire Load/Inflation Chart | Maxxis USA
Inflating to Max PSI is an easy answer that will get you by, but it is not necessarily the best answer.
http://www.tirerack.com/tires/tirete...e.jsp?techid=1
Below is a document put out by Goodyear stating that you can increase your maximum speed by inflating up to 10 PSI over the minimum for a given load.
Personally, my trailers minimum is 50, my tires maximum is 65, I have been running 55.
File Type: pdf Marathon_Special_Trailer_Applications.pdf (115.2 KB, 16 views)
tire, tires
