Old 05-01-2011, 07:37 AM   #1
tires balancing
I am considering to have the tires balanced on my minilite. I dont understand why the trailer manufacturers dont balance the wheels. Just because we dont ride in the trailer is not a reason to not balance them. If someone did it , can you give us the result how bad the balancing was before you had them balanced?
capucine is offline   Reply With Quote
Old 05-01-2011, 07:43 AM   #2
sherdep's Avatar
From experiance on trailer's - usually a bent rim is the culprit from a really bad out of balance issue -
check to see if you have any wheel weights on the inside - or the other thing is they could be using the sand bags inside the tire which is what they have been using on Motor Homes and Semi Tractor Trailer's - the bag goes around the inside of the tire as you drive around and balances the tire at the same time.
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 05-01-2011, 08:45 AM   #3
Herk7769's Avatar
I spun balanced my Marathons and there are some large weights on there!
Old 05-11-2011, 09:07 PM   #4
amxpress's Avatar
If it spins, rotates, or rolls, balance it.
2013 Palomino Columbus 320RS
2007 Dodge RAM 2500 6.7 Cummins
Reese 15K manual slider
M.I.L. in Florida for good!!
amxpress is offline   Reply With Quote
