08-29-2018, 04:09 PM
Titan Flame Fireplace Beeps
Does anyone have this fireplace AND know how to shut off the beeps every time a button is pushed on the remote? It’s freaking out my dogs.
2019 Rockwood 2707WS
2009 Ram 2500 5.7/3:73
08-30-2018, 07:14 AM
x2
2016 RAM 3500 DRW 4x4 LB LoneStar, w/RDS 33Gal Aux tank, Timbrens, Andersen Ultimate2, SwiftHitch SH04
2018 Chaparral 360IBL w/TST507 TPMS, Lippert GC3 Autolevel, Furrion Backup Cam, Progressive HW50C
2006 RAM 3500 DRW LoneStar Edition
2011 Starcraft 392BHUw/Andersen No-Sway
12-02-2018, 01:35 PM
No takers?
12-02-2018, 02:41 PM
I googled it and saw several complaints. Cover the speaker, poke the speaker coil with needle, cut the wire(and hope it isn't series wired) or wait till someone smarter comes along.
2017 Puma 297RLSS
12-02-2018, 02:51 PM
Give them a treat every time it beeps, lol. Trade one problem for another.
2018 T21TBHW A-Frame
2012 Nissan Pathfinder
12-02-2018, 05:43 PM
Just as confused as you
The speaker is there to let you know the command from the remote has been received. The one on mine beeps whether using the remote or the buttons on the front panel. It should be a piezo speaker, if it's not soldered on the circuit board you should be able to cut a wire or unplug it. But it most likely is on the circuit board. If your good with a soldering iron you can unsolder it. If the fireplace does not work once you have it removed from the board, solder a jumper wire in it's place.
Richard & Jill
12-13-2018, 09:06 PM
We have the same problem with our fireplace. Dogs don't like that sound do they?
I researched it and I think an option may be to squeeze some silicone into the piezo speaker. I may try that if covering it with tape doesn't work. I'd like to hear the beep, just not so loud.
2019 Heritage Glen LTZ 272RL
2018 Ram 2500 CTD
12-18-2018, 10:18 PM
Yeah, it IS pretty loud. One dog is ok, the other trembles...and he’s a 50lb cattle dog.
12-31-2018, 06:32 PM
I finally got to this over the holiday. Tape alone didn’t make any difference. I was reluctant to put silicone in it due to its remote location.
However it was easy to get to so I may try it again when it is warmer.
Removal of the fireplace: slide up/remove trim panel to access/remove four screws and unplug. About 10 short screws to remove rear access panel.
Back cover removed, beeper on board at top left:
Beeper under red loop of wire:
01-03-2019, 09:49 AM
I guess you just unplugged it?
01-03-2019, 01:06 PM
Correct, it was a 3 prong plug.
It was not hardwired.
01-03-2019, 09:16 PM
Thanks Chaps!
Charlie
01-05-2019, 08:15 PM
I did this today. It was pretty easy to get out. I misunderstood what you meant about the 3-prong. I thought you meant the piezo speaker wasn't hardwired.
Anyway, I didn't want to de-solder the speaker or try to break it off. Instead, I squeezed some silicone in it. I didn't have the generator with me, so I couldn't test it. I may go back tomorrow so the silicone can dry. I'll update the result if I do.
2018 Ram 2500 CTD
01-06-2019, 06:38 PM
I went down today to finish winterizing the camper, so I took the generator to test out the fireplace.
Squeezing silicone into the hole made a noticeable difference. It was hard to get the silicone in the small hole though. Maybe if I had made the hole larger beforehand, I could have gotten more silicone in there. But it was much quieter.
If the dog still freaks, I'll re-attack it.
It's an easy fix.
2018 Ram 2500 CTD
06-03-2019, 09:44 PM
Any updates here? I want to silence that thing badly.
Bend, OR
2019 Rockwood 2608BS
2018 Ford F250 6.7 diesel super crew
06-04-2019, 03:43 AM
When I did it, it silenced it quite a lot. But we went camping about 2 weeks ago and it was loud again. I guess after the silicone dried it lost its effect.
Dog still freaked, so I'll have to figure something else out.
2018 Ram 2500 CTD
06-04-2019, 07:12 AM
I may drill it and fill with super glue or remove it.
Bend, OR
06-06-2019, 10:36 AM
Update. I removed the unit and unscrewed the 24 screws on the back panel(there really was 24 screws) and found the piezo. I slowly drilled the back of it until the back came off. There was a foil diaphragm that I pulled out. Plugged it in and tested. Silence! Ran it thru all systems and everything works as before. Success!
Bend, OR
06-06-2019, 03:13 PM
Sounds like a good idea. But I can't visualize what you're talking about. Are you saying you drilled through the circuit board side? Or through the backside of the speaker part, meaning the vertical side? Or, through the top where the small hole is?
Finally, what made the top come off?
If this is easy, I'll probably try it.
Thanks.
2018 Ram 2500 CTD
06-06-2019, 03:21 PM
I drilled thru the top of the piezo (speaker) where the small hole was. I drilled slowly until the back just came off. Disassembly took 95% of time and effort. The heater unplugs from the wall behind the unit. Pretty easy.
Bend, OR
