08-18-2018, 06:38 PM
Torque wrench
Looking for a torque wrench for my TV and tt (wheels) also for the sway bar, in case I have to change., Is 3/4 an over kill or will a 1/2 drive be ok? Thanks
08-18-2018, 06:39 PM
Pick up a torque wrench form HF that goes to around 250 lbs that will cover anything you have to do either in 1/2 or 3/4 drive.
Retired Navy
2016 Flagstaff 26 FKWS
08-18-2018, 06:52 PM
Skip the HF junk. I had one that was close to 50% off and damaged some fasteners. Do a search on Amazon for CDI. That's all I use now. I had 4 HF torque wrenches that I threw in the trash/
08-18-2018, 07:38 PM
for torquing lug nuts and such the inexpensive HF torque wrench is fine. I find it hard to believe your claim of 4 torque wrenches being 50% off either plus or minus when working with the torques for most lugs 90 to 120 lbs ft of torque.
Retired Navy
08-18-2018, 07:53 PM
Only one was which was enough for me to throw them all away.
It's up to each person. You can go get the HF wrenches calibrated but for the amount of work I do with all my cars, boats, motorcycle, bicycles and trailers, I am no longer penny wise pound foolish when it comes to torque wrenches.
The OP said he was going to use it for his vehicle.
08-18-2018, 08:18 PM
One note. If you get a "click" type wrench. ALWAYS reset the torque setting to zero before putting it away. The click works off a spring. If you leave the wrench at anything above zero, the spring will stretch and the wrench will become inaccurate.
Personally, I carry a wrench I got from Lowes that is rated for 250 lbs.
Al
I am starting to think, that I will never be old enough--------to know better.
Tolerance will reach such a level that intelligent people will be banned from thinking so as not to offend the imbeciles. Fyodor Mikhailovich Dostoevsky, Russian Novelist
S.E. Mich. Flagstaff 26FKWS / 2022 F-150 3.5 EcoBoost SCrew Propride
08-18-2018, 08:27 PM
Yep..have always done that. There are people that claim that isn't needed but at all the factories that I worked with, that was always the procedure.
08-18-2018, 09:18 PM
I use a beam torque wrench.
08-18-2018, 09:38 PM
Location: Alberta - East of the Rockies, West of the Rest
1/2", 250# is plenty to do this kind of work.
It doesn't need to be Snap-on but it should have a calibration certificate with the serial # on it and yes, resetting it after use reduces the risk of wearing out the spring.
2018 RAM 5500 Laramie CC
Sold: Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Ordered: 2021....
08-18-2018, 09:51 PM
Who Dares, Wins
Hf "junk" was rated the top torque wrench by family handyman for the dyi'r. Best for quoth for price and accuracy..
I use a hf wrench with the appropriate socket and extension.
2015 Chevy HD D-Max
2022 Impression 315MB
08-18-2018, 10:03 PM
X2!
08-18-2018, 10:19 PM
Yeah not a big fan of HF. Never go there for anything.
Michael & Fran Dilday (Baxter & Honey 2 Labs)
'18 Cedar Creek Champagne 38EL - '17 Ford F350 Lariat DRW w/Reese hitch - TST 507 Color TPMS - Garmin RV 770 LMT GPS
08-18-2018, 10:49 PM
LOL..I would love to see this test and rating....have a link?
There are some things that are good at HF and other things that are not so good. This is one that is not so good.
08-18-2018, 10:57 PM
And they probably don't miss you either .
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
08-19-2018, 12:34 AM
I have a CDI 1/2" and HF 3/8 and 1/4. I recently did injectors on my LB7 and "needed" accurate wrenches for that job. Rather than buying or borrowing more, I found that I could test the accuracy of the ones I already had. I checked all 3 wrenches and found that they were spot on all through their ranges. It took probably 1-2 hours to test all 3 at multiple settings each. Most of this time was spent searching for things of various weights and doing some math.
I was surprised to find my Harbor Freight wrenches 100% accurate. Especially because when I brought one of them home I could easily tell by feel that it was way off... I exchanged it for the one I have now that tested 100% accurate. This was before I learned of the testing method.
This is the method I used for testing...
'04 GMC Sierra 2500HD, CCSB, D/A, MaxBrake, B&W Companion, Retrax Pro, AR Power Steps
2021 Solitude 310GK w/FBP
1969 Camaro RS/SS Convertible
Dad's old 1968 Empi Imp (recently recovered from under 21 years worth of boxes/dust)
08-19-2018, 06:38 AM
Probably not. It's not like I am boycotting them or anything like that - I just like quality tools and don't mind paying the price.
08-19-2018, 06:51 AM
Who Dares, Wins
It's a magazine.. You'd need to go find it. It was published last year (2017,possibly end of 2016) if you go out to find it.
2015 Chevy HD D-Max
08-19-2018, 09:14 AM
I went online and saw one article but it was just a list of 5 HF items they liked. Not a comparison between torque wrenches at all and it was a pretty dumb article. Said nothing about accuracies. I doubt they even did any testing.
08-19-2018, 09:19 AM
Click bait
08-19-2018, 10:03 AM
I have three roll-a-way tool chests two at home and one at the ranch. Home Snap-on and Craftsman mostly Ranch mostly Pittsburg Forge (HF) life time warranty used mostly by hired hands that drop tools where they worked on something LOL. The only major difference I have found in years of use is in the cost. In the TT I keep a HF torque wrench and Pittsburg Forge wrenches (cost not performance), I use the Snap-on Lbs Ft and In Ft at home.
Retired Navy
