Old 04-22-2014, 10:49 AM   #31
dretired's Avatar
Forgot to mention the "exhaust braking" on the 6.7....really nice ..when exiting the freeway for stopping
2014 Crusader 325 TE....2012.. F 250.. Supercab XLT, 4x2 , diesel....days camped 2011 ... 28.... days camped 2012...115 ... days camped 2013...155...2014...171 and counting
dretired is offline   Reply With Quote
Old 11-29-2014, 12:21 AM   #32
I am a transmission tech for a Ford dealer. Tow haul has several benefits for a torque shift 6 transmission. 1. Increases line pressure so when the clutch packs apply it reduces wear on clutches.
2. Modifying shift timing to increase fuel economy and promote hp and torque for optimal towing efficiency
3. Allows for engine braking when going down a grade to help decrease brake lining wear
4. Activation of trailer sway control
I have a 2014 F350, very satisfied with the performance. I haven't seen any internal issues except for solenoid issues and a tcm. Very reliable power train.
jimmyt11664 is offline   Reply With Quote
Old 11-29-2014, 08:33 AM   #33
Always use Tow/Haul when towing TT, regardless of terrain. Computerized transmission keeps the engine revs right in the maximum torque band and greatly increases exhaust brake effectiveness.
"But, oh that magic feeling, nowhere to go." -- The Beatles
2015 Flagstaff 8528RKWS fiver
2013 Ram 2500 CTD Laramie CC SB 4WD Auto
cbconway is offline   Reply With Quote
Old 11-29-2014, 08:45 AM   #34
Done with this
I use tow mode and manually lock out o/d when it starts "hunting" for a gear. My tranny temp stays steady.
I'm a little too truthful, I guess.
Y'all have fun in "Fantasy Land".
4mula1fan is offline   Reply With Quote
Old 11-29-2014, 09:16 AM   #35
mark0224's Avatar
Originally Posted by rockfordroo View Post
Here's what my 2009 Silverado's Owners Manual says:
Tow/Haul is designed to be most effective when the
vehicle and trailer combined weight is at least 75 percent
of the vehicle’s Gross Combined Weight Rating (GCWR).
See “Weight of the Trailer” later in the section. Tow/Haul
is most useful under the following driving conditions:
When pulling a heavy trailer or a large or heavy load through rolling terrain.
When pulling a heavy trailer or a large or heavy load in stop and go traffic.
When pulling a heavy trailer or a large or heavy load in busy parking lots where improved low speed control of the vehicle is desired.
Operating the vehicle in Tow/Haul when lightly loaded
or with no trailer at all will not cause damage. However,
there is no benefit to the selection of Tow/Haul when
the vehicle is unloaded. Such a selection when unloaded
may result in unpleasant engine and transmission
driving characteristics and reduced fuel economy.
Tow/Haul is recommended only when pulling a heavy
trailer or a large or heavy load.
So part of the answer is how heavy your trailer is with respect to you towing capability.
My 2011 Chevy Traverse's Manual says the Tow/Haul mode will also increase the alternator output to charge the trailers battery. It also increases the number of blinks the turn signals will make on a brief tap of the lever from 3 blinks to 6 blinks. This doesn't seem to apply to the Silverado, at least not my year..
Have similar manual, I use it full time if the truck starts to shift because of the hills or when in traffic gets backed. On nice level roads my trucks rpms are the same towing as not so the truck isn't working harder than normal and therefore I leave it off. This was how the mechanic told me to do it when I asked and I get a couple of extra mpg on a trip this way. Have your tranny serviced on schedule and ask if you need to have it done more often if you are towing a lot.
Think about things before you do them make life easier not harder.
mark0224 is offline   Reply With Quote
Old 11-29-2014, 09:44 AM   #36
PPST OGCDG
Frank-VA's Avatar
I use my tow haul all the time when towing.
I have a http://www.scangauge.com/products/scangaugeii/ so I can see the engine oil temp, coolant temp and trans temp.
Frank- VA {:-{)
2004 4x4 Ford 6.0 PS, SCC, SB
2005 Wildcat 29 RLBS
Frank-VA is offline   Reply With Quote
Old 11-29-2014, 10:22 AM   #37
LandJ's Avatar
Tow Haul Button
My truck is still new to me, but I noticed that I can turn it off while cruising. I only have about 200 miles towing with it, but I noticed it acts like there is no load on it once up to speed. I turned it off and the tranny shifted to OD and stayed there. If it starts shifting back and forth, I put it back in tow/haul mode. You really have to "listen" and just find the happy place for your vehicle, IMO.
I should add that it's a '14 Ecodiesel with the 8 speed tranny... all those gears prob make a difference.
John and Linda
2016 Rockwood 2604WS
2017 Ram 3500 CTD SRW
2016 - 47 nights
2017 - 47 nights
LandJ is offline   Reply With Quote
Old 11-29-2014, 02:30 PM   #38
GASPEDDLER's Avatar
Love mine, I especially like the added braking. I'm amazed at how well it holds 6th gear at highway speed in hills and overpasses. It says a lot about that 6.7 Diesel engine.
2012 F-350 4x4 King Ranch Super Duty CC 6.7 Turbo Diesel 3.55 e-locker
2011 Palomino Puma 30KFBDS with Side Paw Kitchen and Bunkhouse
Equalizer E2 Hitch
GASPEDDLER is offline   Reply With Quote
Old 12-05-2014, 01:40 PM   #39
Somewhere recently I read that on the Chevys another change is it increases the number of times the turn signal flashes from 3 to 6, when you just tap it. Tested mine the other day and sure enough that is true.
2008 FR Salem 26TBUD
2010 FR R-Pod 171 (2009-2015)
2010 Chevy Suburban
Honda EU3000is inverter-generator
techntrek is offline   Reply With Quote
Old 12-05-2014, 04:43 PM   #40
I always seem to get dumped on when I suggest people should take a couple of hours and read their owner manuals; who knows what else is in there that they don't know (but SHOULD)?
Here's the response I just got on the Traverse Forum when making the same suggestion to a guy who couldn't figure out how to get his dome lights to turn on when his door opened:
Yeah, I could spend "a couple hours" reading the owner's manual or I could spend 30 seconds searching the internet. It took me less time to get the answer from here than it would have taken me to walk out to the car and get the manual. Thanks for the suggestion though.
From my Silverado Owner's Manual:
Raise or lower the lever for less than one second
until the arrow starts to flash to signal a lane change.
This causes the turn signals to automatically flash
three times. It will flash six times if tow-haul mode is
active.
Holding the turn signal lever for more than
one second will cause the turn signals to flash until
you release the lever.
2011 Traverse LT, 3.6L, FWD
