Old 07-02-2019, 09:33 AM   #1
Towing Changed
Just curious if anyone else ever had this happen. Last year travel trailer towed great. I have not changed anything, and this year the rear of truck feels squirrely when towing. Again, nothing has changed. Any ideas?
Thanks, Scott
scottnlindsay is offline   Reply With Quote
Old 07-02-2019, 09:43 AM   #2
Tire pressures on truck and camper the same as last year? WDH hooked up properly with anti sway device?
2012 CC 36CKTS Touring Edition
2015 Ford F-350 CC DRW Lariat
Joe_GA is offline   Reply With Quote
Old 07-02-2019, 09:45 AM   #3
Maybe the adjustments on the hitch are somehow changed. Not knowing what kind of hitch you have my guess would be that it somehow got out of adjustment. Maybe as the hitch is used it gets "broken in" and needs to be readjusted?
That would be my first guess anyway.
Marty
2016 Rockwood 2703WS Sapphire
2016 F250 SD 6.2L
Martsing is offline   Reply With Quote
Old 07-02-2019, 09:51 AM   #4
I had the same thing happen this trip. We go to the florida keys a lot, and the trailer pulled like a dream with no load/sway control. No sway, no bouncing, nothing. This time we are on a trip to Jellystone park in Madison FL, and the camper towed like crap. It was very squirrely and swayed horribly. The only thing different is that I changed my TV tires. Same exact tires, just new. It started swaying so bad that it set off my truck and automatically reduced the speed. I didn't even know my truck had a sway sensor. Luckily there is a camping world less than an hour from here, so I drove there and bought a sway control hitch. $700 later, I hope it fixes it. We're leaving here in a day and headed to Biloxi, so I hope everything is fixed. It was a long ride here worrying that at any moment the trailer would go nuts.
2019 Forest River Cherokee 294BH Limited
2017 F250 4x4 Diesel
Pure Luck is offline   Reply With Quote
Old 07-02-2019, 09:57 AM   #5
Jim34RL's Avatar
The other issue could be your TV tires maybe worn out or nearly so. There also could be a broken belt in one of the rear tire? How many miles are on your TV tires and how often do you rotate them? Do you have a P rated tires on your truck?
Tires can cause all sorts of issue as they age in tire life and miles!
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 135K+miles
Old 07-02-2019, 10:04 AM   #6
I read recently that new tires need break in time to firm up for towing and otherwise. I think I even read it in my new F150 manual. 500 miles.
Are the tire pressures the same? Is the TT loaded the same? Tongue weight?
2019 Cherokee Wolf Pup 16BHS
2019 Ford F-150 S-Crew 5.5 bed V8 w/tow package
Husky Centerline TS WDH 400-600# spring bars
Boomerweps is offline   Reply With Quote
Old 07-02-2019, 10:22 AM   #7
As many people have said here, check your tire pressures on truck and trailer. Also, if you have a weight distribution hitch, check all the bolts and make sure they are tight.
Before this year's tow I bought a new truck and had to setup my WDH for the new truck. During the process I found a bolt that wasn't tightened up all the way. Made me realize that is something I need to check every new season.
joeuncool is offline   Reply With Quote
Old 07-02-2019, 10:29 AM   #8
I guess I'm breaking in my new tires towing the camper. Fun Fun! Now that you said that Boomerweps, I remember when I put the old tires on "Toyo 35x12.5 AT's" that it was a bit squirrely when new also. I went from load range E to F on the same tire.
Old 07-02-2019, 10:35 AM   #9
Thanks, Scott
I'm going to go out on a limb and ask if maybe your recollection changed?
I know on the first pull of the season (after driving the truck many months with nothing attached) it takes several miles to recall the 'feel' of pulling our 5th wheel. And.. I tow MANY different types of trailers, each one feeling different. Each has its own first couple miles of learning how they react.
Days Camped: '16=46 '17=30 '18=51 '19=53
Old 07-02-2019, 01:11 PM   #10
I have not change anything. Tires are about half worn. They are 10 ply. I have a husky centerline ts. 2014 Silverado 1500 with a 2014 heritage glen 272rlis. This just started this year. I rotate every oil change, that the only thing I did beginning of this season. I am thinking that maybe?. It just feels like the trailer is making the rear of tv feel wierd like squirrely. Even at 30 mph.
Old 07-02-2019, 01:21 PM   #11
Trailer axels still aligned? Nothing broken or loose?
Marty
2016 F250 SD 6.2L
Old 07-02-2019, 01:44 PM   #12
Check your camper suspension, make sure nothing gave way between last year and now. Last year did you tow with any of your tanks full or something in them?
wildcatter is offline   Reply With Quote
Old 07-02-2019, 01:58 PM   #13
llr
How was the wind? I thought mine was a little squirrely a couple times, stopped at a rest area for a quick inspection. As soon as I got out of the truck I new what the issue was, the wind was way higher then I thought and it was actually towing better then expected with the wind.
TT 2017 Flagstaff 831CLBSS Classic Ultra lite
TV 2014 Silverado 2500 HD
llr is offline   Reply With Quote
Old 07-02-2019, 02:00 PM   #14
Here is another possibility:
We had a similar situation happen this year on our back and forth to Fort De Soto (Tampa, FL) from NC. Trailer towed great on the way down. No issues save a truck or two. On the way back it was much more sensitive to sway. We had some wicked storms and crosswinds in SC and had to dial it back to 50-55 from 65. We run an Equalizer 10K. 65PSI trailer/38PSI Truck. P rated SUV tires.
What I realized is that the trailer is built with very close to 11% tongue weight. On the way back, the fridge was much emptier (front of axle). Lots of laundry and towels in the shower (rear of axle) and I hung the beach chairs on the otherwise unused bike rack on the rear of the trailer. Having a rear door adds to the risk as well.
I am assuming my actions upset the balance and got too close or below the 10% recommended tongue weight.
I don't have the ability to load too much onto the front of the trailer but will make a diligent effort to do so next time out.
2019 Rockwood Roo 23BDS
2015 Yukon XL 4x4 5.3 Max Trailering package
2005 Fleetwood Valor (Sun Valley) Sold but not forgotten
azfansinnc is offline   Reply With Quote
Old 07-02-2019, 02:02 PM   #15
Brother Les's Avatar
1) tires.... maybe a belt coming apart on one. You will know for sure when it goes flying through your fender... Jack up and check all tires (turning) for roundness and no 'drag' or lopsidedness.
2) Bearings..... Check RV wheels for play (jack up off ground)... loose bearings from use, may need to tighten one face, grease, if have grease able axles..... Pull off hubs, inspect bearings and repack bearings and seat castle nut correctly if unsure.
3) alignment should be fine unless something broke or wore out. Shackles are light weight and could be bent or elongated. The bolts have a plastic sleeve that breaks down and allows some movement.
Brother Les
Old 07-02-2019, 02:10 PM   #16
JPin AZ's Avatar
I tow my trailer full of water when water is not available and empty when it is. Towed it home one time half full and the trailer swayed a lot more than I cared for.
John
2003 1500 Avalanche 360,000 miles
2011 Rockwood ROO 23SS
JPin AZ is offline   Reply With Quote
Old 07-02-2019, 02:12 PM   #17
Coach
Also check out the suspension of your truck. 2014 is 5 or 6 years of driving. Depending on your mileage, driving conditions and habits, your shocks or springs may be going soft. Is the RV still sitting level when hitched? Perhaps a little more squat has developed.
Cut it 3 times and it's still too short...
2017 Sandpiper 381RBOK
2006 Ram 3500 Cummins Dually
valleyduo is offline   Reply With Quote
Old 07-02-2019, 04:01 PM   #18
Wow, so many things it can be. I just took the truck out without trailer and went for a drive. I turn the steering wheel ever so little at all speed and it kinda feels the same thing. I am thinking maybe my tires.
I dont know why though. They are at 65psi cold and 70psi when driving. Same as last year. Trailer tire are at 65psi cold. Does anyone think adding or taking out some air out of tv tire will help since they are now a little worn from last year?
Truck has 58k miles on it, I dont see any issues with the tv. I will have to look at trailer when I can get a chance to jack it up, although it dont feel like the trailer.
also, I thought of the tongue weight. Not being enough, it felt like it towed a little better one time I had the black tank full. Thoughts?
TV and TT are still sitting level.
Thank you all for replies.
Old 07-02-2019, 04:14 PM   #19
dodr33's Avatar
Shocks go out fast when towing, my OEM ones became very soft after only 2 years of towing
2017 F150 EB SCRW
2018 Shamrock 233S
dodr33 is offline   Reply With Quote
Old 07-02-2019, 04:22 PM   #20
Check your tt tires. Could be a flat spot or separated cords
Artspe is offline   Reply With Quote
towing
