Old 09-14-2013, 05:12 PM   #51
Phat Phrog Stunt Crew
elind's Avatar
Originally Posted by Platokidd View Post
Never heard of any chevy half ton that low. My 98 k1500 was 6600 lbs.
Be nice when they all start using same test for ratings instead of writing what ever they feel it is to boost sales
Stalemate: J2807 Truck Towing Standard - Truck Trend News
I just found a 2013 Chevy 1500 Ext, 4.3Lt V6/3.23 rear end and all it can pull is 4400 Lb. All trucks are not created equal, even in the same class.
2014 Wildcat 327ck
elind is offline   Reply With Quote
Old 09-15-2013, 07:44 PM   #52
Platokidd's Avatar
Not gonna pull much with a sixbanger Forgot about that 4.3.. I had the motor in my 1985 c10 (1st truck)with a 4 barrel holly carb and it was a real dog
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
nights of camping
2017-67 / 16-92 / 15-73 / 14-60 / 13-33
Seasonal
Old 09-18-2013, 01:39 PM   #53
I finally did it. Been worried about towing a long distance but made a 432 one way trip to Ohio last week. Everything went great. I'm now ready to really enjoy the TT without losing sleep the week before heading out. Drove up in two days but returned in one for nine hour drive. Longest would want to tow. Next time I'll make it two five hour days.
2013 Flagstaff 27RLWS
2014 Ford F150 Ecoboost
30 nights in 2015 so far
roanmountaincampers is offline   Reply With Quote
Old 09-18-2013, 01:42 PM   #54
Platokidd's Avatar
You Da Man!!!
nights of camping
Seasonal
Old 09-18-2013, 02:55 PM   #55
Brother Les's Avatar
Originally Posted by vcarbona View Post
Well I'm going to be upgrading to a 3/4 ton TV and getting a travel trailer as well in the near future. Currently I tow a popup with a 1/2 ton TV. The popup is a rockwood HW276 which is about 19ft long counting the hitch. I have to admit that while I was looking at some of the 30 ft long and 11ft high TTs, I was a bit intimidated if not down right scared. I've never pulled such a monstrosity before!
Has anyone ever been in my shoes? How did you overcome your fears? I welcome any advice. I'm starting to tell myself that I can probably only do 30 ft. Not sure if I can handle 35 footers! Would I now need to be very selective of the campsites I pick?
Thanks in advance!
Has anybody been in your shoes? Just everyone. You will be fine after some 'practice'......
Been 'pulling' since I was 16 years, I have always had a CDL. I am a seasoned citizen (old age is only in the mind).....
1) Get the right equipment for the job. 1/2 ton will handle a 30 footer alright, but you will know you have a load. 35 footer.... you will almost abuse a 1/2 ton. Diesels are better than gassers for pullin'.
2) Getting that big boy going is the easy part.... stoppen'..... sometimes not so easy. 2 second distance.... I don't think so...... It will not stop when you think it should. Speed and Distance..... Learn how to use the trailer brakes... not too tight, but not to loose.
3) going straight, that big boy will follow you any where. Going around a corner and he (the unit) wants to cut to your inside. And take out the curb and power pole or drop off in that close ditch. Turning 'right', hug the left side of the road and watch your mirrors (40% of the time look in your mirrors) as you go around the corners. 'Go long', do not 'cut short'...... If you are on the 'wrong track', hit the flashers and stop..... don't drive yourself into a worse condition. Five minutes of holding up traffic and a short back up is better than ripping off part of you units side or dropping off in a 3 foot ditch.
4) backing up is more hazardous than going forward..... Do not.... Do not 'guess'.... do not 'trust' anyone. When backing into a spot... get out of the tv and do a walk around..... go slow backing.... get out and do another walk around.... go slow.
5) Speed kills.... especially if you have not practiced (and you practice by doing) for years..... I have always found that if I get in a hurry.... bad things happens..... if I 'slow down' I will get there a lot faster.....
6) enjoy the toys for the big boys.....
Brother Les
Old 09-18-2013, 03:38 PM   #56
Platokidd's Avatar
What does it matter? People will continue to pick and choose what they believe. Most predict that the new standards will actually lower towing capabilities, yet many people are exceeding the current capabilities.
Well you might be right. But it would matter to me in buying / shopping a truck knowing they all had to pass the same test to get there numbers
nights of camping
Seasonal
Old 09-19-2013, 11:39 AM   #57
Mister's Avatar
That was what was killing this truck too... The rear end was somewhere in the low 3's... No amount of displacement will overcome that kind of handicap. Though I suppose diesels would have enough torque.
2008 F150 FX4 5.4L & 3.73s
2014 PTM Tracer 3200BHT
Yes...I've finally made it to Prime Time!
Mister is offline   Reply With Quote
Old 09-19-2013, 12:14 PM   #58
elind's Avatar
I have 2013 Silverado Crewcab 1500 with 5.3L/ 6 speed/ 3.42 rearend. It's tow rating is 9,500 lb and I pull a 34'8"TT/ 7013 dry weight. We went to Goshen this summer (1900 miles) and it felt good all the way. My only problem? DW saw and wants a Wildcat 327 she found at the Rally and my Silverado can't pull it! (Just made the first payment).
2014 Wildcat 327ck
Old 09-19-2013, 01:38 PM   #59
Mister's Avatar
Wisdom of experience... Everyone should read this and practice the advice. Thanks Brother Les.
Old 09-19-2013, 04:03 PM   #60
chiefly1's Avatar
Lots of really great advice in this thread. I would just add to adjust the mirrors and know your blind spots so you can avoid expensive problems. Pick your first few outings carefully until you get more experience and feel more comfortable. Buy some radios to avoid the yelling when backing into a site. A lot less stress that way! Have fun!!
chiefly1 is offline   Reply With Quote
