Old 07-16-2018, 06:07 PM   #1
Trailer Aid
When we bought our TT I bought the trailer aid xl for when we have a flat tire also have a 12 ton Jack
Has anyone ever used one and their thoughts about it.
Gdub2 is offline   Reply With Quote
Old 07-17-2018, 09:36 AM   #2
SeaDog's Avatar
Welcome to the forum its a great place to get your questions answered. Which one are you talking about the Trailer Air or the Jack makes a difference.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 07-17-2018, 11:04 AM   #3
The trailer aid
Old 07-17-2018, 11:15 AM   #4
lakewood90's Avatar
I have used the "plus" version successfully to change a flat on a previously owned 28' TT and was really happy I had it. Easy to use. I do recommend the "plus" version because it gives and extra inch of lift which was important in my case. I still have it and have used it to change tires on a utility trailer that I own.
Tiffin Allegro Bus 43QRP DP
(Sold)2016 Sunseeker 3010DS
TOADs: Honda CRV and Jeep Grand Cherokee Overland 4 x 4
lakewood90 is offline   Reply With Quote
Old 07-17-2018, 09:38 PM   #5
Thanks for sharing your experience using the trailer aid. I am glad that i bought
the plus. Looks easy to use.
Old 07-17-2018, 09:55 PM   #6
asquared's Avatar
I used it on my old 30’ tt (7300 lb loaded weight). It did not raise the other axle off the ground. Have not tried it on my fiver.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 07-17-2018, 10:02 PM   #7
Just make Sure the "Trailer Aid Plus" will lift your Trailer! On some Leaf Sprung axles they will NOT allow the "Flat tire " to clear for Spare to be installed! Check Before you NEED it! Youroo!!
Old 07-17-2018, 10:15 PM   #8
HONDAMAN174's Avatar
I tested mine and had to put down a level of legos to get it off ground. Also had to cram a stubby screwdriver into the legos to give some grip for trailer aid other wise it slipped.
Practice first to know your equipment
Just glad to get away
Old 07-18-2018, 09:49 AM   #9
Broken Toe
Cowracer's Avatar
I don't have one, but I have used curbs, rocks, wood or other such things when it comes to changing trailer tires. any port in a storm, ya know....
Tim
FROG Member MO-0008-571 Since 20124444444444My Project Blog: https://cowracer.blogspot.com/
2016
Rockwood Signature Ultralite 8329ss
Rallies Attended:
Cowracer is offline   Reply With Quote
Old 07-18-2018, 10:30 AM   #10
Thanks for sharing all your experiences and comments I'll do some practice runs to make sure
it will work on my TT if not the old standby jack and blocks will always work
trailer
