Old 10-28-2014, 10:21 PM   #1
bigdog 616's Avatar
Trailer Tires
Okay looking to upgrade my trailer tires Maxxis or Goodyear would appreciate some feedback on both looking to upgrade to eight ply from six
Sent from my iPad AIR using Forest River Forums
bigdog 616 is offline   Reply With Quote
Old 10-28-2014, 10:50 PM   #2
acadianbob's Avatar
I put 25,000 miles on a set of Marathons with no issues whatsoever.
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
Old 10-29-2014, 03:49 AM   #3
ARLO
I jumped fropm the standard tire up to 10 ply to match the truck amd am very happy with the performance. 10000 miles, little tread wear, no bubbles, bumps or separations. I am very anal about tire pressures and inspections. I deal with a majo distributor and he recommended Towmax. He actually had no failures with them as opposed to one of the ones mentioned above. He believes that mfrs really put the bare minimum tire required to do the job and maintenance and overloading have a lot to do with premature failure.
rlocicero is offline   Reply With Quote
Old 10-29-2014, 05:09 AM   #4
I've had both. Either one would be fine. Just be hyper vigilant with regards to the correct air pressure per load and the weight distribution.
Ham_Bone is offline   Reply With Quote
Old 10-29-2014, 06:48 AM   #5
wmtire's Avatar
What size tires do you currently have on your TT? If you have 14 inch diameter rims, then neither Maxxis nor Goodyear make a 8 ply tire.
If you have 15 inch diameter rims, you will be able to find the tires.
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 10-29-2014, 07:16 AM   #6
Poppy94's Avatar
I recently saw a sandpiper limp into the dealer due to major damage to both fender wells on both sides-catastrophic failure to tires if you ask me. That made me start thinking about converting to 10 ply bias like my flatbed car hauler trailer. I've blown one tire before on it & the tire collapsed around the rim (saved it from asphalt damage) and it didn't fly apart & destroy my fender wells. What are pros/cons?
Poppy94 is offline   Reply With Quote
Old 10-29-2014, 08:02 AM   #7
acadianbob's Avatar
If you have 14" tires, I'd recommend Kumho 857's. D rated.
Old 10-30-2014, 07:53 AM   #8
bigdog 616's Avatar
Looking at 205/7515 8ply maxxis dual axle trailer max weight 7.000
Old 10-30-2014, 08:36 AM   #9
WestCoastRV'er's Avatar
My trailer has 14" rim and tires. Is there any benefit to upgrading to 15" rims and tires?
2011 2902ss Rockwood Ultralight
2008 Grand Cherokee 3.0L Diesel (255 hp @ 2900 rpm / 430 lb-ft @ 1,400-2,800 rpm)
3P ProPride Hitch
RV Mods
Wandering RV Life
WestCoastRV'er is offline   Reply With Quote
Old 10-30-2014, 08:43 AM   #10
acadianbob's Avatar
You would increase load capacity; and also expense. Do you have the clearance to do it?
Seriously, look at the Kumho 857. More load capacity, great tire, speed rated to 99 mph. Look on tirerack.com
tire, tires, trailer
