Closed Thread
Old 11-11-2018, 10:40 AM   #1
csc
Trailer tires vs. truck tires.
When I eventually have to replace my 4 tires , should I go with a better truck tire and not those china bombs?
csc is offline
Old 11-11-2018, 11:26 AM   #2
5er_tom's Avatar
I did that and I think it was a mistake. I am now back to ST tires. The truck tires do not flex as much as ST tires and that adds a lot of stress to the RV suspension that it is not designed to handle. I broke shackle spring supports 3 times, requiring a welder to come fix it.
I recommend you go to a higher rated ST tire. From C to D, or E to F, etc.
Tom & Renée
Durham, NC
2015 Wildcat 295RSX
2018 Ford F-350, 4x4, Diesel, CC, Long Bed
5er_tom is offline
Old 11-11-2018, 12:16 PM   #3
csc
Thanks.
csc is offline
Old 11-11-2018, 12:29 PM   #4
NMWildcat's Avatar
About half our RV group stay away from ST tires and go with LT tires. Just have to watch load rating is sufficient. No problems that I have heard of in thousands of miles with either the tire or the suspension. These folks usually have larger fifth wheels.
The rest of the group stay with ST tires but go up at least one load range when possible.
Maxxis M8008 seems to be the favorite. Carlisle next and then the new Goodyear ST.
Scott and Liz - Southern NM
NMWildcat is offline
Old 11-11-2018, 12:35 PM   #5
saus's Avatar
Just as 5er Tom stared. When I went to purchase new tires for my fifth wheel I asked the gentleman which tires to get. He stated, definitely ST tires for the same reasons 5er tom stayed.
2016 Forest River Wildcat 314BHX
2018 Ford F-350 DRW 6.7 Diesel
saus is offline
Old 11-11-2018, 12:35 PM   #6
saus's Avatar
Stated
saus is offline
Old 11-11-2018, 01:16 PM   #7
USAF Ret
truck tires on RV
Just to muddy the waters a bit, I've had truck tires on my last 3 fifth wheel rigs and driven the units many, many thousands of miles without a problem. Sorry, not being contrary, just another opinion.
RandyN is offline
Old 11-11-2018, 01:41 PM   #8
Tire Input
I grew tired of the China bombs and went to truck tires. No problems with them and we've put over 15K miles on them over 5 years. I'll stick with truck tires.
DrippingDuo
Chappy and Liz
Dripping Springs, TX
DrippingDuo is offline
Old 11-11-2018, 01:57 PM   #9
LT tires
I've run Firestone Transforce LT tires and have put about 80K on them without issue. They still look good and probably run them a bit longer. I keep my speed down and check tire and air pressure often....
FrankinKane is offline
Old 11-11-2018, 02:47 PM   #10
The advantage of trailer tires over truck tires is that truck tires are not designed to handle the sidewall loads associated with sharp turns with multiple axels. If you are pulling single axel trailers or never turning sharp to cause side load, truck tires usually work fine but it only takes getting in a bind one time to cause problems.
Safe travels.
Huntnfishn is offline
Closed Thread
tire, tires, trailer, truck
