Old 05-22-2016, 08:14 PM   #1
boatman
boatman's Avatar
Trouble with Satellite signal
Keep getting a message that reads receiver does not detect SWM, Could the problem be that the new receiver D12-100 is not compatible with my old dish and LNB?
boatman is online now   Reply With Quote
Old 05-22-2016, 08:23 PM   #2
Mr. Dan's Avatar
Don't know about that... but it might be that you are running your signal through a splitter or a bad coax connection.
You might post back with more info. on the antenna and receiver for the smart people who might be able to help.
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 56; booked = 6
Old 06-02-2016, 12:25 AM   #3
Do you have an option to select multi-switch? If so try that. I had the same message SWM not detected on my new dish and LNB so I changed to multi-switch and that worked. Good luck.
sandb is offline   Reply With Quote
Old 06-02-2016, 03:07 AM   #4
Learjet's Avatar
Do you have a SWM antenna and are you using a proper power inserter to power SWM antenna?
-2017 Ram Cummins, Aisin DRW 3.73, 4x4
-2015 Wildcat 317RL
-B&W Companion , MorRyde pinbox
Learjet is offline   Reply With Quote
Old 06-02-2016, 08:36 PM   #5
boatman
boatman's Avatar
Thanks for the reply, I did find a setting to switch to multi switch and that solved my problem.
Old 06-02-2016, 08:45 PM   #6
Mr. Dan's Avatar
Thank you for reporting back with your solution. That gives honor to those who have tried to help.
Old 06-05-2016, 07:20 PM   #7
Glad to hear that worked for you.
satellite
