Old 06-11-2010, 05:00 PM   #1
TT True Weight
Hey It's me again...The Brochure on the website for our trailer 's floorplan says Dry Weight = 6403lbs and when we were buying ours we noticed that little yellow tag on the bottom of the door (and on the side of the TT) that says This trailer's Dry Weight 6100lbs.....
Correct me if am wrong but I was under the impression they weigh the trailers right before the ship them to dealers, The website and brochures are for reference, right?
Don't get me wrong, we were looking for TT's within a criteria (less than 6500lbs) so we knew what we were buying was within our expectations.
I was just curious what your experiences have been in this subject.
2011 Wildwood 27BHSS
2007 Sub 5.3L 3:73
Hot DW
1 Princess & 2 Busy Boys
Ventura County, CA
Willie is offline   Reply With Quote
Old 06-11-2010, 05:12 PM   #2
MtnGuy's Avatar
Hmmm.....doesn't make sense that the sticker weight is less than the brochure weight. What does the certificate of origin or the title list?? I know ours was exactly the listed brochure weight plus all of options as listed in the brochure. I don't think they weigh them as they come out the door......they just calculate to get the final weights.
Old 06-11-2010, 09:51 PM   #3
We haven't gotten the title yet, we just bought it 3 weeks ago. the certs and the tags both indicate 6104lbs. I was assuming the weight on the brochures and website are with all the options reference weight.
By the way - How is your truck? Didn't your truck breakdown? or Do I confuse you with someone else?
2007 Sub 5.3L 3:73
Hot DW
Ventura County, CA
Old 06-11-2010, 10:04 PM   #4
milzat's Avatar
The only way to know the true weight is to weigh it at a weigh station.
California Weigh Stations List
milzat is offline   Reply With Quote
Old 06-11-2010, 10:09 PM   #5
grhodes50's Avatar
When I purchased my TT the sticker stated the same dry weight as the brochure, 6,104 lbs. When it came back from the factory after they replaced the sidewalls because of delamition the sticker states 6,348 lbs. dry weight.
So I guess they do actually weigh them when they leave the factory.
Gary & Trish
2018 Nights Camped - 5
Old 06-12-2010, 07:57 AM   #6
MtnGuy's Avatar
Good memory on my truck. It was back home in 3 days after the front wheel 4x4 actuator solenoid was replaced. The solenoid on those trucks was placed on the firewall right where the cowl water runs off, allowing water & dirt to collect and make the unit malfunction. The Ford fix was to place a shield around the new solenoid so that the water and dirt is diverted around. It is a known problem, since Ford already had a solution and part to put back on. Another Ford better idea.
Old 06-12-2010, 09:17 AM   #7
Well, I also noticed on all the new 20+ TT's we saw before buying ours is Mfg's don't put those stickers on the cabinet doors with the weight specs anymore. Someone told me they do weigh them now beofre they ship them and slap the sticker on it. I wasn't sure how much true there was on that.
MIKE- thanks for the link, I had always wanted to know the scale locations so I can go and get this done....nothing big since I am under TV capacity but it sure is strange.
2007 Sub 5.3L 3:73
Hot DW
Ventura County, CA
Old 06-12-2010, 09:19 AM   #8
I had something like that on my 89 Sub starter, dealer put some kind of cover and problem was solved along with two different starters. Good to hear your partner is back in action.
2007 Sub 5.3L 3:73
Hot DW
Ventura County, CA
Old 06-12-2010, 12:16 PM   #9
MtnGuy's Avatar
It wasn't the starter solenoid. It is the solenoid that operates the vacuum to the actuators in the front hubs.
Old 07-11-2010, 06:48 PM   #10
Wanna Be Camper
SaskCampers's Avatar
Ours is listed at 6417 dry and 8812 GVWR on the site and the sticker on the side shows actual 7213 dry and GVWR of 8521.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2016: 3 2017: 0
