Old 10-01-2013, 05:25 PM   #11
jwebb3's Avatar
Yes, there are a couple of bolts through the support shaft that I assume you remove to check the connection at the antenna. I'm planning to do that this weekend along with checking the connections at the booster.
jwebb3 is offline   Reply With Quote
Old 10-01-2013, 05:49 PM   #12
Carknocker Family
Ida Ratherbe Camping's Avatar
Mine wasnt connected properly in the junction box where the booster switch is located. They had the cable and the air channel lines reversed. Figured that out while installing our Jack antenna.
Nights camped 2015...20
Nights camped 2016...20
Nights camped 2017...24
2017 Ram 2500
2014 Salem 32BHDS
Ida Ratherbe Camping is offline   Reply With Quote
Old 10-01-2013, 06:49 PM   #13
jwebb3's Avatar
Did the cable reception work like it should? It works fine on mine. It's just the antenna reception that is not so good.
Old 10-01-2013, 07:49 PM   #14
Carknocker Family
Never hooked it to a cable so cant answer that. We hooked the TV to a set of Rabbit ears borrowed from the neighbor camper and picked up channels. Thats when we decided to look into our "build quality"
2017 Ram 2500
2014 Salem 32BHDS
