Old 09-30-2013, 05:00 PM   #1
jwebb3's Avatar
TV antenna reception on 2013 Surveyor SV 301
I'm sure others here have this same type antenna on their little home away from home. At first I was excited about the way it looked and that it would simplify my life by not having to crank it up and down. To say the least though, I've been very disappointed with it's performance. The stations that it does pull in are always pixilated and going in and out. Almost like it never totally locks in on the signal. I DO have the booster turned on. I also set the TV for antenna reception and do a scan. Any idea what I could look for that might be wrong?
jwebb3 is offline   Reply With Quote
Old 09-30-2013, 05:26 PM   #2
Ford Idaho's Avatar
Do you need to turn it?
MY HD antenna cranks up and then I need to turn it to find the strongest signal direction.
Old 09-30-2013, 05:29 PM   #3
jwebb3's Avatar
No way to turn it that I've been able to find. It's fixed in place on the roof.
Old 09-30-2013, 05:46 PM   #4
A friend of mine has that same thing on the top of his RV. You can tell by the shape that it's directional, and yet there is no way to rotate it. I think they expect you to park your RV in the right direction. I'd get rid of that piece of junk ASAP.
Edit: I see that their website says it's not directional. Your experience would seem to indicate otherwise (as would the shape).
Old 09-30-2013, 05:52 PM   #5
We had that same one. Our first issue was that it wasn't actually hooked up to the anything in our trailer. After we had it hooked up, it still was not worth much, even in my driveway. We had it removed and went with the Jack antenna, it is directional, but doesn't crank up and down. Much better.
2012 Surveyor SP 220
Stephanie, David, and Callie, the furry toddler.
StephanieLynn is offline   Reply With Quote
Old 09-30-2013, 05:58 PM   #6
Ford Idaho's Avatar
Where inside would the antenna be, the pic looks like in a corner.
Have you checked the connections.
Old 09-30-2013, 06:12 PM   #7
On my friends, there is no visibility of the antenna from inside the RV.
Old 09-30-2013, 06:28 PM   #8
jwebb3's Avatar
Originally Posted by Ford Idaho View Post
Where inside would the antenna be, the pic looks like in a corner. Have you checked the connections.
There isn't anything inside. The antenna is just mounted up on the roof. The booster is in the wall beside the TV. When the booster isn't turned on it picks up nothing. It actually works best when I'm parked in the driveway at home. Anywhere else I've been it's the same old pixilated mess.
Old 10-01-2013, 05:12 PM   #9
jwebb3's Avatar
Photo showing antenna on the roof.
Old 10-01-2013, 05:18 PM   #10
Ford Idaho's Avatar
So would you need to unscrew the antenna from the roof to check the connection or is it under the wings?
