Old 06-23-2014, 10:16 AM   #21
Plain Old Member
Same here on the loose connections. One leg of our 50a Marinco inlet was stripped and loose. Found that installing the EMS. Definitely worth checking all of them to eliminate the hot spots.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
Old 06-23-2014, 11:06 AM   #22
Ret E-9 Anchor-clanker
donanddona's Avatar
Is there a preventive measure that we can consider doing to prevent this? I'm thinking (sorry I'm a mechanical engineer) a big fuse added to the positive wire at the battery terminal like 40amp for the 30amp users?
donanddona is offline   Reply With Quote
Old 06-23-2014, 11:17 AM   #23
TURBS's Avatar
Although this is not something we all want to happen and the OP is very lucky to have caught this and not be injured and there's no EXCUSE for shoddy workmanship.
THIS IS a house on wheels!
I don't know about y'alls roads but around here I'm lucky to have a camper behind me when I arrive at my destination.
Thinks WILL loosen, break, fall apart.
Sorry but some if not a majority of problems happen because your house drives or gets towed down the great USA hi ways we have.
OK I'm done with that.
Old 06-23-2014, 11:53 AM   #24
DDC
DDC's Avatar
Originally Posted by wmtire View Post
It was a tongue in cheek comment. Timex was just trying to bring a little humor with his ironic post, which was actually a self- deprecating statement.
I got a chuckle out of it, as everyone else should, as that's how it was intended since he was being sarcastic about himself. It's all good.
I figured that and that why I responded like I did (tongue in cheek).
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline   Reply With Quote
Old 06-23-2014, 12:03 PM   #25
DDC
DDC's Avatar
If no one reports these types of issues to the NHTSA then a recall will never get generated and the governing bodies think every thing is ok. When I read some of the stuff people have to do to a piece of property they just payed thousands of dollars for it amazes me that FR does not put 'some reassembly may be necessary' in the small print on their brochure.
Old 06-23-2014, 12:17 PM   #26
PhoneDude 8289's Avatar
Originally Posted by presley01 View Post
After taking delivery on our 8289 last Dec I was moving stuff around in the front storage and noticed a wire from the battery to the disconnect was loose. Had to pull the battery to tighten it but also found several other loose connections. Following that I got into the distribution panel, more connections that were not tight, some as much as a full turn of the screw or more. Ended up pulling all the plugs and checking them, plugs had push in type connections, nothing to tighten. It's amazing how many loose connections were in this RV.
With the above being said I am by no means unhappy with Forest River, just think they need "QUALIFIED" installers on things like the electrical. On previous RV's I have and still will check electrical connections and everything else on a yearly bases on occasion finding a terminal that needed to be tweaked, sort of like putting a torque wrench on the wheel lugs before a trip. I feel better doing it.
Joe & Beverly
2014 Ram CTD, CC, SB
2014 8289WS lifted
PhoneDude 8289 is offline   Reply With Quote
Old 06-23-2014, 01:02 PM   #27
SKnight's Avatar
Yikes! My slide switch stuck momentarialy this weekend, luckily it was grit or something as I tapped the other side and the switch moved and a black speck hit the counter.
With as much wire as these things have mistakes like this are inexcusable.
Old 06-23-2014, 01:27 PM   #28
Lexi2007's Avatar
I'm new to the forum but as far as your non-refundable trips, why not contact the parks, explain the situation [by now you may have some documentation that you could share with them] and as for a special accommodation to re-schedule your visits. The worst than can say is no.
On another note, I'm so glad no one was hurt. I can't even imagine what it must have been like. Good luck.
Ken & Val [Lexi's mom] Moczygemba & Tori the dog
Adkins, TX
2017 Coachmen Concord 300 DS [Lexi III]
Lexi2007 is offline   Reply With Quote
Old 06-23-2014, 01:40 PM   #29
OL Creeker's Avatar
Regardless of what many think, FR does NOT monitor this forum. You're gonna have to contact them yourself.
Alan, Kathy & Cooper the camping cat
2014 Cedar Creek, 36CKTS
2013 GMC 2500 Denali
Duramax/Allison
Full timers since 5/30/2013
OL Creeker is offline   Reply With Quote
Old 06-23-2014, 01:46 PM   #30
Herk7769's Avatar
My camper came equipped from the factory with one.
HAM CALLSIGN - KC3FFW
forest river
