06-23-2014, 10:16 AM
#21
Plain Old Member
Same here on the loose connections. One leg of our 50a Marinco inlet was stripped and loose. Found that installing the EMS. Definitely worth checking all of them to eliminate the hot spots.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
06-23-2014, 11:06 AM
#22
Ret E-9 Anchor-clanker
Is there a preventive measure that we can consider doing to prevent this? I'm thinking (sorry I'm a mechanical engineer) a big fuse added to the positive wire at the battery terminal like 40amp for the 30amp users?
06-23-2014, 11:17 AM
#23
Although this is not something we all want to happen and the OP is very lucky to have caught this and not be injured and there's no EXCUSE for shoddy workmanship.
THIS IS a house on wheels!
I don't know about y'alls roads but around here I'm lucky to have a camper behind me when I arrive at my destination.
Thinks WILL loosen, break, fall apart.
Sorry but some if not a majority of problems happen because your house drives or gets towed down the great USA hi ways we have.
OK I'm done with that.
06-23-2014, 11:53 AM
#24
Originally Posted by wmtire
It was a tongue in cheek comment. Timex was just trying to bring a little humor with his ironic post, which was actually a self- deprecating statement.
I got a chuckle out of it, as everyone else should, as that's how it was intended since he was being sarcastic about himself. It's all good.
I figured that and that why I responded like I did (tongue in cheek).
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
06-23-2014, 12:03 PM
#25
If no one reports these types of issues to the NHTSA then a recall will never get generated and the governing bodies think every thing is ok. When I read some of the stuff people have to do to a piece of property they just payed thousands of dollars for it amazes me that FR does not put 'some reassembly may be necessary' in the small print on their brochure.
06-23-2014, 12:17 PM
#26
Originally Posted by presley01
After taking delivery on our 8289 last Dec I was moving stuff around in the front storage and noticed a wire from the battery to the disconnect was loose. Had to pull the battery to tighten it but also found several other loose connections. Following that I got into the distribution panel, more connections that were not tight, some as much as a full turn of the screw or more. Ended up pulling all the plugs and checking them, plugs had push in type connections, nothing to tighten. It's amazing how many loose connections were in this RV.
With the above being said I am by no means unhappy with Forest River, just think they need "QUALIFIED" installers on things like the electrical. On previous RV's I have and still will check electrical connections and everything else on a yearly bases on occasion finding a terminal that needed to be tweaked, sort of like putting a torque wrench on the wheel lugs before a trip. I feel better doing it.
Joe & Beverly
2014 Ram 2500 CTD, CC, SB
2014 8289WS lifted
06-23-2014, 01:02 PM
#27
Yikes! My slide switch stuck momentarialy this weekend, luckily it was grit or something as I tapped the other side and the switch moved and a black speck hit the counter.
With as much wire as these things have mistakes like this are inexcusable.
06-23-2014, 01:27 PM
#28
I'm new to the forum but as far as your non-refundable trips, why not contact the parks, explain the situation [by now you may have some documentation that you could share with them] and as for a special accommodation to re-schedule your visits. The worst than can say is no.
On another note, I'm so glad no one was hurt. I can't even imagine what it must have been like. Good luck.
Ken & Val [Lexi's mom] Moczygemba & Tori the dog
Adkins, TX
2017 Coachmen Concord 300 DS [Lexi III]
06-23-2014, 01:40 PM
#29
Regardless of what many think, FR does NOT monitor this forum. You're gonna have to contact them yourself.
Alan, Kathy & Cooper the camping cat
2014 Cedar Creek, 36CKTS
2013 GMC 2500 Denali
Duramax/Allison
Full timers since 5/30/2013
06-23-2014, 01:46 PM
#30
My camper came equipped from the factory with one.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
06-23-2014, 01:51 PM
#31
NELA
One could rightfully assume provisions regarding this fact are engineered into the design, no?
If age is a state of mind, and I've lost my mind, I'm AGELESS, right?
Give me 40 acres and I'll turn this rig around:
Flagstaff 5er 2014 8528 IKWS, Platinum Package, Regency Interior "Buffy"
F250 Super Duty 2013 Tuxedo Black "Biff"
Days camped 2014: 30
06-23-2014, 01:57 PM
#32
Lol I think not😆
06-23-2014, 01:59 PM
#33
NELA
Then why are there "park models" versus non park models?
What is the difference?
06-23-2014, 02:04 PM
#34
Park models have different "features" for "seasonal" camping.
06-23-2014, 02:05 PM
#35
Sliding deck doors, longer, atrium style windows.
More "cabin" like.
12 foot wide in some cases.
http://www.rvia.org/?ESID=PMRV
06-23-2014, 02:10 PM
#36
NELA
Trailer & a Park Trailer?
By Lynda Altman, eHow Contributor X
Lynda Altman Lynda Altman started writing professionally in 2001, specializing in genealogy, home-schooling, gardening, animals and crafts. Her work has appeared in "Family Chronicle Magazine" and "Chihuahua Magazine." Altman holds a B.A. in marketing from Mercy College, a black belt in taekwondo, master gardener certification, a certificate in graphic arts and a certificate in genealogy.
View my portfolio
Found This Helpful
Travel trailers
There is a difference between a travel trailer and a park trailer. Although both are towed behind a vehicle, they are in different classes of RVs and serve very different functions. Other People Are Reading
- Definition of Travel Trailer
- Truck towing travel trailer A travel trailer is a recreational vehicle (RV) that is towed behind a car or truck. It is used for temporary vacationing and frequent travel.
Types of Travel Trailers
- Tear drop travel trailer Travel trailers range in length from 10 feet to 45 feet. They can be as simple as a pop-up camper or elaborate as a high-end fifth-wheel camper with a washer and dryer.
- Sponsored Links
Definition of a Park Trailer
- A park trailer is more like a mobile home than a travel trailer. It is towed behind a large vehicle like a truck or SUV. They are not made to travel often.
Park Trailer Uses
- A park trailer is designed to stay in one area for an extended period of time. Many senior citizens use park trailers to go to a warm destination in winter, then pack up and go to a cooler area in the summer.
Considerations
- People who travel often will prefer a travel trailer. Those who like to stay in one area for months at a time will prefer a park trailer. Park trailers usually cost more than travel trailers
Read more : http://www.ehow.com/facts_6052974_difference-trailer-_amp_-park-trailer_.html
06-23-2014, 02:12 PM
#37
Lol think of it this way.
Your camper is in a mini earthquake every time you tow it.
#38
NELA
What is the difference between a park model and a mobile home and cottage?
Follow publicly
Follow privately
- Unfollow
Im a Little confused, i know they aren't like trailers, fr sure , but we bought one its called a chalet. to me its like a normal house but much much smaller,,, some say its a ...show more
#dmRosAdWrapper-MainNorth iframe{width:100%}
Best AnswerAsker's Choice
Here is the straight scoop:
Some call them Park Models, others Cabins or Cottages. These homes are normally less than 400 square feet and are classified as RV's. They are not considered mobile or manufactured homes.
Most park model homes are built sightly better than a quality RV, however unlike a mobile or manufactured home, Park Model Homes do not meet stick built housing requirements and are not certified by Housing and Urban Development (HUD).
Although they are great for the dollar spent.
Good Luck,
JCF Lending Group
Source:
http://www.chattelmortgage.net/mobile_ho...
Asker's rating & comment
thanks
Other Answers (1)
acermill answered 5 years ago
A 'park model' is a specific type of mobile home, generally built to the same standards as is a mobile home, rather than to recreational vehicle trailer standards.
Park models are thusly named because they are specifically less than 400 square feet in measured size. And that magical size number is what makes a home a property taxable home or not.
06-23-2014, 02:15 PM
#39
Checking my Tracer now...
On the Tracer, where is the Short Stopper for the slide motors? The Short Stoppers for the stab. jack motors are under the frame but when I pulled the panel with my slide switches (above TV) , I do not see a Short Stopper...
2011 RAM 2500 ST Crew Cab 5.7 Hemi
2011 Primetime 3150BHD Touring Edition
Days camped in 2018- 25
2017- 31; 2016- 36; 2015- 37; 2014- 31
06-23-2014, 02:22 PM
#40
And it should be built to withstand that earthquake because they are destined to be towed, right from the moment it comes off the line. If you make a product to be towed then towing it should not destroy it.
