Old 10-12-2010, 06:21 AM   #11
Mr. Black's Avatar
You are gonna be hard pressed to find a 6 lug 16" 110 PSI wheel. I have never seen one before.
Steve
1999 Ford Superduty F250 PSD CC SB 6spd 4x4.
B&W goosneck/companion hitch, Airlift 5000 airbags.
2006 Sierra F28 Rear Kitchen 5th Wheel, 31' = 10k pounds.
Nights camped in 09-14, 2010-23
Mr. Black is offline   Reply With Quote
Old 10-16-2010, 06:43 PM   #12
Originally Posted by NWJeeper View Post
He was talking to the OP CountryGirl not you....
Oh good, I thought maybe I'd lost my mind there for a minute.
CountryGirl2 is offline   Reply With Quote
Old 10-18-2010, 08:28 PM   #13
LWG
Thank you steave But I found a set at etrailer.com for less than $45.00 each with free shipping.I have them under carport now.I will wait till closer to spring to install tires.I found a local tire dealer that said he would start with the 235/85/16 .If they wont work the he would back down to a smaler size. We think the 225/75/ 16 would be an easy fit but would try the larger size first. I found one who upgraded to 245/75/16.I have the wheels now this spring I will do the tires.
LWG is offline   Reply With Quote
Old 10-18-2010, 08:32 PM   #14
Mr. Black's Avatar
You found a set that will do what? 120 PSI? or 16"? or both?
Anyways if you go with LT tires which many large trailers came with from the factory then a 245 75 16 tire is a perfect match size wise to the standard 235 80 16 ST trailer tire.
Steve
5th wheel
