Old 09-13-2010, 09:45 PM   #1
LWG
Cool upgrade from 15in wheeks to 16in wheels
I have a 2005 Wild Cat 30ft with rear bunk beds.It has 225-78-15 6 lug wheels. I want to upgrade to the 16 in wheels.Has anyone ever done this or will this work.I beleave when loading with water, grocerys all the other things for a extended vacation the 15in tires will over loaded and will be unsafe.
LWG is offline   Reply With Quote
Old 09-13-2010, 09:58 PM   #2
Mr. Black's Avatar
The registration sticker on the side of our trailer shows a 15" spec 6 lug setup as standard, yet the trailer came with 16 inch 235s.
Can it be done? more than likely. The big thing is making sure there is enough distance between the two tires. Mine are around 2 inches apart and I can barely get my scissor chock in there.
Also there will be a noticable height difference which means you may have to re-level your trailer.
Also, the tire size is less critical than the weight rating. In other words don't go by size, go by load rating of the tire. C, D, E ect.
Steve
1999 Ford Superduty F250 PSD CC SB 6spd 4x4.
B&W goosneck/companion hitch, Airlift 5000 airbags.
2006 Sierra F28 Rear Kitchen 5th Wheel, 31' = 10k pounds.
Nights camped in 09-14, 2010-23
Mr. Black is offline   Reply With Quote
Old 09-14-2010, 10:07 AM   #3
LWG
Thank you Mr.Black for your reply. The tires are now 6in apart.I estimated with the 16in tires I looked at they would be 3in apart.The waight rating from 225-75-15 which is about 2300lbs to the 235-85-16 3400lbs would be 0ver 1000lbs of safety gained.
Old 09-14-2010, 01:03 PM   #4
Head Rambler
Those 235/85-16's will be 3" bigger diameter then the 225/75-15's. Be sure to check the clearance on the top of the tires also. You don't want them rubbing, remember they'll be 1" closer to the top than the existing tires.
Gotta go campin!
Old 10-09-2010, 02:44 PM   #5
Our 09 Wildcat came with 16 inch wheels and the only thing I see wrong is our cover doesn't fit well on the spare tire. : )
CountryGirl2 is offline   Reply With Quote
Old 10-11-2010, 06:54 AM   #6
Most likely if you are overloading the tires now, you are overloading the axles. Putting on bigger tires will not solve that problem. Your best bet is to get the unit weighed to see exactly how much weight you are carrying.
2004 Flagstaff 8528RLSS - 2005 Dodge 2500 QC LB Hemi
tgif: let's RV - HobbyTalk
HobbyTalk is offline   Reply With Quote
Old 10-11-2010, 10:11 AM   #7
huh? I never said anything about overloading anything.: )
Old 10-11-2010, 04:00 PM   #8
NWJeeper's Avatar
He was talking to the OP CountryGirl not you....
Ed & Wendy
www.nwjeepn.com
Old 10-11-2010, 09:48 PM   #9
Mr. Black's Avatar
Most six lug axles are 6k pounds. Not all I am sure but most are.
If room is available I would absolutly make the switch to 16s providing that I needed tires.
I wouldn't swap out a set that meet the load requirments of the trailer that I have had good luck with, IE no blowouts.
Steve
Old 10-12-2010, 04:51 AM   #10
cardinal4fun's Avatar
Just a thought, if you are going to 235/85 16 tires with a G rating (110 psi) you are looking at only one tire mfg and thats goodyear. If you find another its more than likely made in china and thats not good.
3500 Ram 5.9l diesel
08 35 RLT Cardinal
5th Airborne Pin Box
cardinal4fun is offline   Reply With Quote
5th wheel
