Old 03-17-2016, 12:15 PM   #11
"The ONLY 16 inch ST rated tire worth a damn is a Goodyear G614 but they are $$$$."
So true!!
Ultraboy is offline   Reply With Quote
Old 03-17-2016, 12:24 PM   #12
I'm one of the many that swapped out the Marathon "MayPops" for Michelin LT Xrib. Was a REALLY GOOD move as tire problems went away. There are several internet sites that sell tires and have the inflated dimensions available online. I went to one and compared the sizes and tire ratings before selecting the Michelins. Chose the Xrib series (expensive!) over others because of extra sidewall strength, and because they were recommended by many Rvers.
RubberNail is offline   Reply With Quote
Old 03-17-2016, 12:45 PM   #13
Boots49's Avatar
Send a message via Skype™ to Boots49
from all the aspects I have read on my Wildcat, RF figures what load each axel & tire can handle, what the pin weight is on the truck, then they add it all up & give you the GVWR, GAWR,& Tongue Weight. Then they all the bell & whistles to your camper, You can not put tires with less carrying capacity than what it came with or you will have a problem. The only play you have is the CCC, but I found you do not have a lot of playing room.IMO.
Al & Susanne
Aka: Puss 'n Boots
Wildcat 31 TS - Silverado 2500 DuraMax Diesel
Tip of the Day: Stay safe, have fun and never leave the cat out in the rain!
Boots49 is offline   Reply With Quote
Old 03-17-2016, 02:15 PM   #14
Fulltime family RVer
The Sailun in equivalent size and LR G is showing promise at quite a lesser cost.
Old 03-17-2016, 06:57 PM   #15
Jerry01's Avatar
If you do upgrade to a load range G tire make sure your rims can handle the increased PSI. Jerry
2005 GMC Sierra 2500HD, Duramax 2WD CC/SB
2013 Cardinal 3030RS full body paint
B&W Companion slider, air bags, EFI Live Custom tuning by So Cal Diesel
Jerry01 is offline   Reply With Quote
Old 03-17-2016, 07:05 PM   #16
Gold Miner At Heart
Papa-t's Avatar
Originally Posted by VizJedi View Post
I'll echo what ependydad said. As a rule, ST tires have a higher load capability than the same size LT.
My setup is a good example. My Chaparral has the ST235 80 16 E on it. The side wall says @80 psi- Max load is 3520. I have the Firestone Transforce HT tires on my truck. The size you are looking at, LT235 85 16 E is rated with a Max load of 3042. Link That's nearly 1000 lbs difference. My 5er weighs 12,500 before I put anything in it. The GVWR is 14,500. If I load it up, the pin weight is about 2400 lbs. If I do the math right, that still leaves over 12,000 on the trailer axles. The LT tire would be completely maxed out. (3042 X 4= 12,168) I'm not comfortable with that.
I completely agree the recent Marathons are garbage, but I would still go with an ST over an LT unless the LT was a F or G load range. But then you'll need to check your wheels to make sure they can handle the additional air pressure.
j
X2
Papa-t is offline   Reply With Quote
Old 03-17-2016, 08:15 PM   #17
I checked into the Michelin Ribs and the cost was almost the same as the G614's. So, a rib is $249, and a G is $272, then I'll go with the G's.
2016 Ford F-350 Lariat CC, 4x4 SRW. B&W turnover with extender. 2015 CC Silverback 29RE, fitted with Reese Goose Box. Amateur Extra Class K5TS, 2016 nights camped 16
Davidg is offline   Reply With Quote
Old 03-17-2016, 08:29 PM   #18
Kenny kustom's Avatar
I have four smason g's waiting for spring to go on.
Great price
Old 03-17-2016, 08:48 PM   #19
Great price
What is "smason g's"
Old 03-17-2016, 08:49 PM   #20
ferguson65's Avatar
Nope. The GY G614 is an LT tire. Same with the Sailun S637.
Both are only designed and intended for trailer use, but are still LT tires.
2013 F350 dually
2015 Palomino Puma 351THSS Premier Edition
2015 Nights camped 15
2016 Nights camped 5
ferguson65 is offline   Reply With Quote
tire, upgrade
