Old 10-13-2016, 07:44 AM   #41
keeprr's Avatar
Just got back from 3800 mile trip of towing my 5er with my 2015 GMC Dmax. Needed to put DEF in after traveling 3600 miles.
2016 Open Range Light 297RLS Fifth Wheel
2015 GMC 2500HD 6.6L Duramax
Days Camped. 2015: 17
Days Camped 2016: 58
keeprr is offline   Reply With Quote
Old 10-13-2016, 08:37 AM   #42
My Cummins no longer requires DEF....
2015 Ram 3500 CC SRW SB 6.7 Diesel Powered Baby!
2015 Sabre 36QBOK-7
2015 Nights Camped: 23
2016 Nights Camped: 27
2017 Nights Camped: 5
mikeysotp is offline   Reply With Quote
Old 10-13-2016, 10:48 AM   #43
mike.t's Avatar
Towing uses more fuel which means using more DEF
2015 Salem 27RKSS
2015 Ram 2500 CC 4x4 Cummins
55' Chevy Bel-Air
Burgers on the BBQ and a cold beer
mike.t is offline   Reply With Quote
Old 10-14-2016, 05:46 PM   #44
B and B's Avatar
Must be one of those states with no inspection. Here you would get hauled in by the DOT for non compliance.
Old 10-14-2016, 06:22 PM   #45
mike.t's Avatar
B and B He also doesn't care about the air his grand children will have to breath.
2015 Salem 27RKSS
55' Chevy Bel-Air
Old 10-14-2016, 09:11 PM   #46
If you cared about the environment you wouldn't have had children-and thuse no grandchildren-which impact the environment more than a deleted diesel. In addition, you'd walk or ride a bike to work, disconnect your home from the grid, not use any electricity or water, not urinate or defecate, and hold your breath so as not to add to the CO2 burden.
I wonder how many millions of gallons are burnt unnecessarily each year in the USA because of DPF regenerations which on my truck, costs me about 2 gallons of gas every 220 miles while not towing and every 100 to 150 mile while towing. In addition, the partially clogged exhaust filter creates back pressure that must be overcome with more fuel usage. Modern diesels get worse fuel economy than diesels did 20 years ago.
The EPA is pressuring oil industry to make oils that are thinner to improve fuel economy. New diesel oils in 10w30 grade offer a 0.1% improvement in fuel economy over 15w40. The thought is that 0.1% will result in millions of gallons of fuel saved in the USA. Think of how much more fuel we could save by eliminating exhaust filter regenerations.
BTW, there has been a war on diesels for the past 12 years or so by our EPA. If they are so concerned about soot, how come they are not doing anything to eliminate soot caused by gasoline direct injection engines? GDI engines such on turbocharged engines such as the Ecoboost and other GDI engines emit more soot then my modern diesel. Attacking GDI engine particulate emissions - SAE International
The use of GDI technology is again the government's fault by pushing unrealistic fuel economy standards on auto manufacturers. If you have a direct injection gasoline engine in your car, you are pushing out harmful soot that effects me but not my children cuz I'm a responsible citzen and didn't want to burden mother earth anymore with overpopulation.
If you are a strict environmentalist like me, please follow my lead and spread the word to not drive on November 8, 2016. Think of the million of gallons we can save in fuel if like minded individuals who love our planet stayed home that day and didn't drive.
Skyliner is online now   Reply With Quote
Old 10-14-2016, 10:45 PM   #47
mike.t's Avatar
Why not post this after your comment about "My Cummins no longer requires DEF" And explain it that way. Instead of your little
2015 Salem 27RKSS
55' Chevy Bel-Air
Old 10-15-2016, 09:54 AM   #48
NMWildcat's Avatar
This standard environmentalist reply is probably the most ridiculous comment I have ever heard. I can only think it is meant to incite strong emotions and responses but is so overused it is meaningless. To me, Environmentalism is just a new religion based on beliefs of those with an agenda and short on true, provable, facts. I'll just stick to my own belief that everything in moderation is the best way to go.
Scott and Liz - Southern NM
NMWildcat is online now   Reply With Quote
Old 10-15-2016, 10:06 AM   #49
mike.t's Avatar
NM. This is my feelings on this subject i don't much care what your take on the matter is!
2015 Salem 27RKSS
55' Chevy Bel-Air
Old 10-15-2016, 10:07 AM   #50
NMWildcat's Avatar
Likewise!!!
gas, upgrade
