Old 08-18-2007, 05:29 PM   #1
Water Heater
Hi folks I'm new to the forum. My wife and I took out our 07 Wildwood T23FBL for the first time last week to Baja and had a blast. The one downer for our trip was that our faucets and showers released hot water in short spurts. If I were to turn on only the hot water it would come out cold with occasional hot spurts. Is this normal or do we have a bigger problem?
Fumanchuki is offline   Reply With Quote
Old 08-18-2007, 06:08 PM   #2
powerboatr's Avatar
simple things first
i would check and make sure the by pass vavles are not open or partially open, this would allow water to by pass the water heater and is used to winterize the water system
second bleed all the air from your tank just to be sure the air is out
you can bleed it by manually opening the upper pressure releif valve and hold it open till water runs out of it, either by using your fressh water pump or hooking up shore water
hope it helps
Living in the Piney Woods of Texas.
powerboatr is offline   Reply With Quote
Old 08-18-2007, 07:49 PM   #3
Cyber Phrenologist
Radio's Avatar
If you have an outside shower, check to see if the faucets are closed. You can open the faucets and not get a flow until you squeeze the "thumb thing" on the nozzle. The hot and cold water will mix inside the faucet body if the valves are left open.
Radio is offline   Reply With Quote
Old 08-20-2007, 10:29 PM   #4
Thanks for the tips, hopefully I'll get this figured out. I'm not dure if my outside shower head has a trigger but I'll check, if not I have a feeling bleeding the heater might do the trick. Thanks.
