Old 09-13-2016, 12:00 PM   #1
redcloud1's Avatar
What air pressure
What air pressure are you guys running in your LT tires when you're not towing your trailer
redcloud1 is offline   Reply With Quote
Old 09-13-2016, 12:12 PM   #2
AquaMan's Avatar
That's going to depend on your truck.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
Old 09-13-2016, 12:55 PM   #3
redcloud1's Avatar
It's a Chevy Silverado half ton
Old 09-13-2016, 01:23 PM   #4
clr
I would look at the sticker on the door and go with that for the unloaded truck. Of course that may be for P radials or whatever came on the truck but I would not go less than what the sticker recommends.
Chuck & Sandra
Engineer/Teacher
2010 F350 CC 6.4
2015 Prime Time Sanibel 3601
clr is online now   Reply With Quote
Old 09-13-2016, 02:11 PM   #5
redcloud1's Avatar
Right now I'm running 70 pound in them while I'm towing the trailer
Old 09-13-2016, 05:04 PM   #6
I would lower it to 50-55. That will give you over 5K tire load rating per axle, way higher than your axle ratings. You probably don't have very good ground contact right now running on only the center of the tires.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 09-14-2016, 07:25 AM   #7
Failure is my business
2Evil4U's Avatar
The 20 inchers on my RAM recommend 39psi for normal use. I run them at 44psi rated max when towing.
Current vehicle list: 17 RAM 3500 4x4 Cummins Aisin 4.10, 24 Cedar Creek 40CBK
2Evil4U is offline   Reply With Quote
Old 09-14-2016, 10:37 AM   #8
Jim34RL's Avatar
First of all what size are your tires and rims. Also what letter designation is on the tires such as E,D or C. I know most LT tires are E but I do not want to assume. On your tires should be a recommend weight/air pressure setting such as 3195LBS at 80PSI. IF so this is the recommend maximum air pressure setting of your tire.
Now the best thing to do is to weigh your truck and trailer on a certified scale. With this information you can determine the proper air pressure to support the load that the truck is carrying when towing. Your tire dealer and or tire manufacture can provides an air inflation table showing what the tires will support at what air pressure. Ask your tire dealer what is the minimum air pressure to use in your tires when you are empty. Anything lower than that pressure and you can ruin the tires.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 145K+miles
Old 09-14-2016, 02:08 PM   #9
redcloud1's Avatar
The tires are 265/75R-17 load range e
Old 09-16-2016, 08:03 PM   #10
2011 f150 running 18 in nitto Tera grapplers e rating 70. Psi when towing 60 psi when not
Clancy vibe272bhs
timothy clancy is offline   Reply With Quote
Old 09-16-2016, 08:47 PM   #11
Stormrider151's Avatar
2012 F150. 45 unloaded. 65 towing.
Retired Fire Dept Battalion Chief
2016 Ever-Lite 232RBS
2012 F150 FX4 W/Max tow & Ecoboost (Best tv ever)
2018 F250 Lariat (ok but I miss my F150)
Getting old ain't for wimps!!!
Stormrider151 is offline   Reply With Quote
Old 09-19-2016, 03:45 PM   #12
I run 75psi when towing, and 65psi when not. I also have to remember to deflate airbags when not towing for a smooth ride.
ccsvolsfan is offline   Reply With Quote
pressure
