Old 11-28-2014, 01:41 PM   #11
BigD3's Avatar
Originally Posted by asquared View Post
The answer is it is limited by the weakest component. Whether it is tires, axles etc.
Then why not change the door tag AWR to reflect that condition ??
2006 FORREST RIVER CEDAR CREEK SILVERBACK LTDTS 33 FEET
2011 FORD F250 XLT 6.7L DIESEL
BigD3 is offline   Reply With Quote
Old 11-28-2014, 01:51 PM   #12
offroad's Avatar
Originally Posted by TURBS View Post
A v5 hitch is only rated to 10,000 lbs.
12,500 with wdh.
My Curt V5 2" Receiver hitch is rated for 16K weight carrying, and 17K weight distributing.
Tongue weight is 2400lbs, my truck is less of course.
2017 Open Range - Light 297RLS, BX1 Gooseneck
2014 Ram 2500 4x4 CCSB 6.7L 68RFE
offroad is offline   Reply With Quote
Old 11-28-2014, 01:53 PM   #13
TURBS's Avatar
I'm sorry 12,000 lbs.
But here's the real deal.
I think op must have an Iv hitch.
Class V hitches are weight carrying (WC) and weight distributing (WD) hitches depending on the vehicle and hitch specifications.Class V hitches used as weight carrying are rated up to 12,000 lbs. gross trailer weight (GTW) with a maximum trailer tongue weight (TW) of 1200 lbs.Class V hitches used for weight distributing are rated up to 17,000 lbs. gross trailer weight (GTW) with a maximum trailer tongue weight (TW) of 1700 lbs.Your ball mount and hitch ball need to both be rated for Class V to safely tow these weight loads. To use this class of hitch for weight distribution requires a weight distribution system.A Class V hitch has a 2-1/2" square receiver opening.Class V hitches attach to the vehicle frame only
TURBS.
Old 11-28-2014, 01:55 PM   #14
TURBS's Avatar
Class IV hitches are weight carrying (WC) and weight distributing (WD) hitches depending on the vehicle and hitch specifications.Not all Class IV hitches are rated to be both. See the specific hitch for that information.Class IV hitches used as weight carrying are rated up to 10,000 lbs. gross trailer weight (GTW) with a maximum trailer tongue weight (TW) of 1000 lbs.Class IV hitches used for weight distributing are rated up to 14,000 lbs. gross trailer weight (GTW) with a maximum trailer tongue weight (TW) of 1400 lbs.A Class IV hitch usually has a 2" square receiver opening.A higher class drawbar does not increase the towing capacity of the hitch. To use this class of hitch for weight distribution requires a weight distribution system.Class IV hitches attach to the vehicle frame only.
TURBS.
Old 11-28-2014, 01:57 PM   #15
BigD3's Avatar
TURBS.
I can tell you are much more familiar with this than I am. I have never used the rear hitch. I am looking at the question based on a 5th wheel hitch, if that makes any difference.
Dick
Old 11-28-2014, 01:59 PM   #16
offroad's Avatar
I'm just quoting what Curt says about it, my WD hitch is a 12K Equal-i-zer.
Old 11-28-2014, 02:00 PM   #17
TURBS's Avatar
Dick
Let me tell you this,
I pull a sabre 5th wheel with a 2,000 lb pin weight 14,000 lb gross with my 3/4 ton duramax with no issues.
What are your camper specs, and your payload rating on your tire loading sticker on the truck?
TURBS.
Old 11-28-2014, 02:03 PM   #18
TURBS's Avatar
Dick
It doesn't make a difference.
Basically your truck is limited to a single component which gives you the final tow rating for your truck.
It may be tires , hitch, axles hard to say.
I'm guessing it's limited to your receiver hitch even tho your not using it .
TURBS.
Old 11-28-2014, 02:06 PM   #19
Kaadk's Avatar
TURBS.
Turbs,
Unless I'm mistaken, in his original post he was asking about GVWR, not tow ratings. So the hitch really has nothing to do with the limits on GVWR.
The surest way to lose is to play Marco Polo with a ventriloquist.
Old 11-28-2014, 02:07 PM   #20
TURBS's Avatar
Originally Posted by Kaadk View Post
Turbs,
Missed that.
TURBS.
