Old 06-13-2018, 02:42 PM   #11
Jack
Bottle jack at spring perch on road. Floor jack at home. If I want all four wheels off the ground; tongue jack all the way “down”. Jack standd under frame innrear. Tongue jack up andjack stands under frame st front. May have to put spaacer blocks under jsck.stands if not tall enough.
ID:	175766   Click image for larger version
pdqparalegal1 is offline   Reply With Quote
Old 06-13-2018, 03:18 PM   #12
Torsion axles change things when jacking
If you have torsion axles you can not jack them on the tubes like a spring axle. On spring axles I jack from the equalizers between the axles. On torsion axles I use a bottle jack between the tires with a block of wood that goes to the trailer frame. The jack does not go to the trailer frame without a block of wood in between.
I can do two wheels at a time this way. My TT weighs about 6500# and I use a 6-8 ton jack
2018 Rockwood 2509S Mini Lite
Past: 1984 Road Ranger 20', 1988 Kit Companion
1984 Starcraft 24 foot popup
TV: 1999 Dodge 2500 Cummins 4x4
Honda EU2000i Generator, 200 Watts Solar
Ham Callsign KD7UM
UT_Grandpa is offline   Reply With Quote
Old 06-13-2018, 03:29 PM   #13
I have torsion axles so I made these. One for bottle jack I carry and one for air/hydraulic jack I keep at home.
Name:	BJ Adaptor in use.JPG
ID:	175773   Click image for larger version
Name:	Air-Hyd Jack & Adaptor.JPG
Old 06-13-2018, 09:35 PM   #14
Canadian Member
I picked up a 20 ton bottle jack at a great price at Princess Auto (the Canadian version of Harbor Freight). Where you jack depends on the type of suspension and axles you have.
2019 Rockwood Signature 8290BS
Old 06-13-2018, 10:06 PM   #15
Blackrock's Avatar
My Jack
For those of you who don't know Jack. Meet my Jack.
Picked up this half size railroad jack at a yard sale over 20 years ago.
2016 RAM 1500 - 2016 Keystone Laredo 265SRK
The road goes on forever and the party never ends.
Blackrock is offline   Reply With Quote
Old 06-16-2018, 09:57 AM   #16
2007 WildCat 32QBBS
05CrewDually's Avatar
I've just seen 2 of these style "railroad jacks" on Craigslist and the seller was asking in the $500 range! And it wasn't even gold plated. Crazy to me.
I have my own fabricated jacking/leveling system made from tongue jacks and it will lift all four tires off the ground. It has worked flawless for a couple of years now and cost was about $250 in materials.
For other trailers I use the air over hydraulic 20ton bottle jack.
ID:	176085Click image for larger version
05CrewDually is offline   Reply With Quote
