Old 12-19-2014, 05:02 PM   #1
onetexasoldman's Avatar
Who do I contact about under rated axles on Brookstone
2011 37' Brookstone 5th wheel been having trouble with the tires wearing. Have just taken it in to have axles aligned and was informed that the axles that are on the trailer are at least 1000 lbs UNDERRATED for the trailer.
Has anyone had to deal with this?
2015 Bighorn 37' Front Living Room
2012 Dodge Cummins 3500 4x4
Live at 9000' in the rockies just out of Colorado springs
onetexasoldman is offline   Reply With Quote
Old 12-19-2014, 05:24 PM   #2
arpipeliner's Avatar
Assuming its lippert axles. When I replaced my springs and shackles etc. to get back correct axle to axle alignment. They sold the parts for under half price. No pictures or anything DW gave them serial number and what the problem was and how I was planning to fix it. They offered the price reduction.
The info should be on the axle tube and number. I would have a print out of the actual weight of camper and what was told to you by the shop. If prepared they might send the heavier ones. All they can say is no and then try a camper dealership.
arpipeliner is offline   Reply With Quote
Old 12-19-2014, 05:42 PM   #3
hrlyguy2's Avatar
I asked about my sandpiper. Forest river told they will not do nothing about it.Being I bought it used .
2007.5 Chevy 3500Ltz cc lb Duramax
2010 Sandpiper 345 RET (SOLD)
hrlyguy2 is offline   Reply With Quote
Old 12-19-2014, 05:42 PM   #4
TURBS's Avatar
What is the axle sizes?
What is your camper gvwr?
What is your pin weight?
Old 12-19-2014, 07:25 PM   #5
I am picking the trailer up sat will see what axles and all
thanks for the reply wife says we are looking at trailers tomorrow had enough problems haha
Old 12-19-2014, 07:36 PM   #6
hrlyguy2's Avatar
Oh I know well about problems with FR.
Been there
It bad when when you have a 2 or 3 year old rv and it's in the repair shop every year
Old 12-19-2014, 08:13 PM   #7
Dave_Monica's Avatar
What is the dealer basing this on? What does your label indicate for camper GVWR and axle rating?
Dave
Old 12-19-2014, 10:32 PM   #8
I didn't take it to a dealer/stealer! It was a business that knows trucks and trailers and axles
I also sent an email to Coachman, yeh as if I think they will reply with something with all of us out there with the same problem
It has been in the shop for many elec problems that they cannot fix or understand how or why they wired it the way they did.
Old 12-20-2014, 07:13 PM   #9
ok just got rid of THOSE problems bought a 2015 Bighorn Heartridge 40' 5r with front living room
Old 12-20-2014, 08:02 PM   #10
LOL someone who probably knows nothing telling you you have under rated axles? How do you know for sure? 6000 dual axles will handle a 14000 pound fifth wheel with weight to spare. You have to remember, pin or tongue weight does not count toward axle weight. If your strictly looking at axle weight and GVWR he is right. But he is also completely WRONG!
donniedu is offline   Reply With Quote
Old 12-20-2014, 08:11 PM   #11
TURBS's Avatar
It's what I was guessing to......
Which is why I asked.
Old 12-21-2014, 03:32 PM   #12
Retired
RubyDually's Avatar
Very true.... You could subtract the un-sprung (<<< is that even a word?) weight of the wheels, hubs and axles from that too...
The largest reason we got rid of our last trailer was because it had 5200 pound axles on it... That would have been fine with the 12,500 GVWR however.... The design of the trailer had 3 slides, water heater, kitchen & bathroom all on the left side which put an 800 pound imbalance on it so the axles were overloaded on that side. This caused the springs to flatten out only on the left making that side to be lower than the other so there was a definite noticeable lean to her.
Replacing the springs with heavier ones worked for only 1/2 a season so we traded her in for the Sabre and its 6000 pound axles.
Live and learn!
2014 Chevrolet Silverado 3500 LTZ CCLB DRW D/A - Rancher Grille Guard - Transfer flow 40 gallon Toolbox/Tank Combo - Line X - Edge Insight
2015 Palomino Sabre 33CKTS - Platinum Edition - Progressive Industries EMS HW50C - JT Strong Arm Stabilizers - Ground Control 3.0 - 320 Watt Solar with 2000 Watt Inverter
RubyDually is offline   Reply With Quote
Old 12-22-2014, 01:27 PM   #13
If that is true, the NHTSA National Highway and Traffic Administration, should be able to give you some assistance.
What is your trailer GVWR from the label? Your axles (GAWR) x2 should be about 80% of the trailer GVWR, the the other 20% carried by the pin of the trailer.
If the trailer GVWR is 12,000 pounds, then the 4 trailer tires carry 10,000 pounds or about 2,500 each. And the remaining 2,000 pounds is carried by the pin and the tow vehicle suspension.
2013 Flagstaff 8528IKWS, 2006 F-350 6.0L
DickiedooFlagman is offline   Reply With Quote
Old 12-22-2014, 01:56 PM   #14
Thanks everyone for all the info I am alot smarter now about axle weight.
I traded it in for a 2015 so the trailer is at the dealer now. I had alot of other issues and just didn't want to put more money into it.
axle, roo
