Old 07-12-2016, 07:43 PM   #1
Pipcoo15's Avatar
WIFI boost
Have contacted a lot of camp sites, look at reviews, an it seems they all have wifi issues. Is there anyway to boost.reception.
Pipcoo15 is offline   Reply With Quote
Old 07-12-2016, 08:00 PM   #2
There is a little box in the upper right hand corner of your screen for searching. Type in WIFI. You will have loads of reading to help you out.
2001 Ford F250 7.3l converted to F350 specs
2014 Flagstaff 8528RKWS
2006 model year Border Collie
Mtelkman is offline   Reply With Quote
Old 07-12-2016, 09:05 PM   #3
MrNiceGuy's Avatar
Yes you can boost your WiFi signal. What you will find in most cases is that WiFi signal strength is not going to be your issue. Limited bandwidth when connecting to the campgrounds WiFi is where you will have issues. In my experience campgrounds have inadequate bandwidth when they begin to fill their sites.
2015 Crusader 315RST
2011 Silverado 2500HD
MrNiceGuy is offline   Reply With Quote
Old 07-14-2016, 03:01 PM   #4
Always Learning
Jim/Silverado2500HD has it right.
The booster sometimes helps, but the issue typically is crappy Internet bandwidth to the campground. No booster will boost that. It just sometimes helps you get a connection to that crappy network.
Old 06-12-2017, 09:43 PM   #5
Depending on the campground your visiting ask them how often they reset there IP address, should be every couple of hours
gijeff58 is offline   Reply With Quote
