Old 02-05-2014, 10:21 AM   #1
5ersabre's Avatar
Winter living improvements
Any suggestions on how to make cold months warmer and enjoyable?
5ersabre is offline   Reply With Quote
Old 02-05-2014, 10:24 AM   #2
jtstromsburg's Avatar
Move south?
Sent by me
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 02-05-2014, 10:26 AM   #3
puff's Avatar
What are your concerns or problems and we might be able to help with some suggestions..!
Glen & Robyn (A.K.A. Puff & Crickit) Full Timers..
2006 F350 6.0 with 3.73 gears, 4X4, Extra-Cab Long Box, Oil/Tranny/P.S. Coolers. Coolant filter. SCT Livewire.
2011 Cedar Creek 36RE, Auto levelers + too much to list..!
puff is offline   Reply With Quote
Old 02-05-2014, 11:46 PM   #4
5ersabre's Avatar
It gets below freezing a lot living in Texas desert weather temps can plunge very low. Keeping my RV warm has been a challenge. I have two floor heaters one in the living area and one in the bedroom. They keep the RV in the 60s depending on how cold it gets it gets colder. They struggle but I can't plug in another one in the main area without tripping a breaker. I am trying to utilize my free electricity vs using propane. Any suggestions on any area of insulation, heaters, etc.?
Old 02-06-2014, 01:17 AM   #5
puff's Avatar
I am not sure what you have for power running into the unit. Sounds like you are on the right track. I would identify what circuits you have in the unit and run a heater on each one. So, if you have three breakers you should be able to run three heaters. This of course depends on the watts of the heaters. Some times it is just trial and error. You can add a shirt or skirting around your trailer to help keep out the cold from the floor area. If you go real fancy and use wood or paneling you can insulate the walls of the skirting. I know some people have even put a heater under their unit to help. Heaters that blow heat are better as they move the air.
Hope all that helps..!
Old 02-06-2014, 04:18 AM   #6
Witch Doctor's Avatar
You might want to try and slip an extension cord from the pedestal 20 amp duplex between your slide and the wall at the bottom and add your 3rd heater to that.
Coachmen M/H
Concord
2018 / 300 DSC
Witch Doctor is online now   Reply With Quote
Old 02-06-2014, 07:05 AM   #7
While I do the same (running 2 electric heaters) I do not try to eliminate propane use. With the two 1500 watt heaters running plus the heat set to 68, the furnace in my 5er was only cycling about once every 45 minutes.
jbrostek is offline   Reply With Quote
Old 02-06-2014, 06:02 PM   #8
What I do is run a 1500 watt heater in the basement off the 20 amp duplex on the pedestal. It is thermostatic controlled and ceramic. Even with that going and the basement reading 60 degrees the 2 low port drains froze. the only way to stop that is to add to shut off valves on the low point drains inside the basement. and keep the water drained in them where they are exposed. Never new Pensacola Florida was going to be 18 degrees. Left the water drip in the galley with the valve open to the sewer, that is the only frozen thing I found. In the CG they they said to do it that way or disconnect the hose and leave the faucet drip on the pedestal........
Coachmen M/H
Concord
2018 / 300 DSC
Old 02-06-2014, 06:57 PM   #9
As I have posted several times, wiring a switch to the furnace blower and run it without the burner to circulate the heat in the camper and also the underbelly and basement. When doing that, the only thing that can freeze is the low point water lines that are below the underbelly and not up inside the underbelly itself. Just heating the basement is not sufficient to circulate air in the underbelly. The tank heaters will help some IF they are working.
Old 02-07-2014, 01:25 AM   #10
puff's Avatar
Your water also can not just drip, it must be a steady stream. A dripping tap will still freeze a water line as there is not enough water movement.
winter
