Old 09-10-2018, 08:04 AM   #1
flashtilley's Avatar
Winterizing 2018 Grey Wolf 29BH
Hi, anyone have any experience winterizing a 29BH? I havenít looked yet to see if there is a winterizing kit installed (hose and valve to suck antifreeze). Any tips with this unit?
Thanks!
flashtilley is offline   Reply With Quote
Old 09-11-2018, 06:39 AM   #2
SeaDog's Avatar
Now is the time to start learning your rig. Start with looking on the outside by your city water and fill connections there may be a connection for winterizing then move to the compartment where the water pump (if you don't know where the water pump is open a faucet and follow the noise) is and then water heater and take a pic of the position of the valves for reference to normal position of the valves. Now you can position them for winterizing. this may not be as easy as someone telling you, but you will know your rig when you are done.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
grey wolf, winter
