Old 12-16-2018, 06:13 PM   #61
Originally Posted by TitanMike View Post
I should take you for a ride in my Volt. If I select "Sport Mode" and floor it when the light turns green you wouldn't be able to grab a $100 bill taped to the dash.
Sport mode isnt that good for "miles per kilowatt" but the torque is definitely there and being put to the road.[emoji41][emoji41]
That was my point. All that torque and the Pious drivers can barely get out of their own way when the light turns green. Don't know if they're really pious or are suffering from range anxiety.
I hate getting behind them.
Hate when they try to merge on the highway, too. Putt-putt-putt.
Guess we should return this thread to its original subject.
2011 Traverse LT, 3.6L, FWD
Old 12-16-2018, 09:14 PM   #62
The original Prius wasn't a true electric vehicle. Kind of half and half with the battery/electric motor only "helping" it to get moving or accelerate (somewhat).
The newer "plug in hybrid" has more battery power but it doesn't work quite like the Chevy (GM) Voltec motor. The Volt is pure electric, getting it's power from battery and/or an internal combustion engine through a part of the motor that becomes generator when needed.
Prius/Pious owners are a little different. A lot like the original VW owners without the Patchouli "aroma" and Daisy on the dashboard.
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change)
Old 12-16-2018, 09:18 PM   #63
Originally Posted by emm-dee View Post
Well, why wouldn’t you expect that. Your state borders the Pacific Ocean.
I see a lot of railroad cars coming through town that have obviously sat on a siding for a while around San Diego or LA. Covered with graffiti, some of which is more "Art" than the stuff the State is buying. They could buy a couple of cases of Krylon, give the "taggers" a couple hundred, and let them decorate away. The taxpayers would come out ahead by millions.
