Old 04-11-2016, 10:22 AM   #1
California to Florida - best route?
We are moving from Sacramento to Ocala Florida and will be leaving mid to late May. We are pulling a fifth wheel and would like suggestions as to best route. This is not a sightseeing trip, just trying to get there. Thank you in advance.
rjwilder is offline   Reply With Quote
Old 04-11-2016, 10:55 AM   #2
leefl's Avatar
If you're just wanting quick, rather than pretty, then you probably only have a couple of real choices.
We'll be doing one of these, in reverse, in the summer (but with some detours) as part of a roadtrip.
Down I-5 to Bakersfield
Cut along SR-58 to Barlow
I-40 to at least Alburqurque
head down I-25 to El-paso
then I-10 all the way to FL (and down I-75 to Ocala)
same route to Alburquerque, but continue on to Amarillo
take SR 287 down through Wichita Falls to DFW
Take I-20 to Jackson MS
SR49 to Hattiesburg MS (can stay overnight in Paul B Johnson State Park)
SR98 down to Mobile
then I-10 to I-75 and down to Ocala
Head all the way down to LA, and head east on I-10 for several days of boredom
We'll be doing #2, (except with a detour west of Alburquerque up to southern Utah)
Staying at Paul B Johnson state park near Hattiesburg, MS
and at American RV park just outside of Alburquerque
and at a Campers Paradise RV park near Sunset TX, between DFW and Wichita Falls
Hope this helps a little.
I haven't actually driven this route myself yet, but have done quite a bit of research.
2015 Rockwood Signature UltraLite 8281WS
2016 Ford F-250 Lariat CrewCab, 4x4, 6.2L V8
leefl is offline   Reply With Quote
Old 04-11-2016, 11:12 AM   #3
waiter21's Avatar
Same route to I-40 - Then stay on I-40 to OK City, then south on I-35 to Dallas to I-10
I'd say Option #1 or #4. I've traveled both, they are good routes.
2001 Coachmen Mirada (Ford F53 6.8L V10) - Toad 2003 Saturn Vue
It won't do MACH 2, but I can get a sandwich and take a pee.
waiter21 is offline   Reply With Quote
Old 04-11-2016, 11:16 AM   #4
Georgia Frog Rally 2018
aceinspp's Avatar
I'd just head south on I 5 till ya hit I 10 around Los Angles. Then head east all the way FL then pic up I 75 south. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
Old 04-11-2016, 02:52 PM   #5
Thank you for the suggestions. I will look at 1,2 & 4 in more detail. I don't care for LA.
Old 04-11-2016, 02:56 PM   #6
Fulltime family RVer
Back in January, I drove I-10 from the San Diego area (Acton, CA-specifically) to Lake City, FL.
Old 04-11-2016, 03:15 PM   #7
RedLdr1's Avatar
To avoid the bad traffic in San Antonio, Texas when using I-10 here are a couple options I have used:
1. Exit I-10 on US290 to Austin, Tx. Then stay on US290 to intersect Houston at the Sam Houston By Pass (Toll Road!) or I-610.
1A. Or take 71 from Austin and intersect I-10 in Columbus, Tx to get back on I-10 faster.
2. Exit I-10 in Boerne, Tx on 46 and take it to intersect I-10 in Seguin, Tx.
Both options avoid a lot of bad traffic in San Antonio. Option 1 is more scenic, through the Hill Country and Austin. Option 2 gets back on I-10 quicker. Either option is usually faster, and much less annoying, than going through San Antonio!
Wayne and Christine
2019 Sunseeker 2500TSF On Order Due "Off Line" on May 18th
2018 Ford Focus SEL Hatchback TOAD
RedLdr1 is offline   Reply With Quote
Old 04-11-2016, 08:51 PM   #8
RedLdr1, thanks for the tips. I will keep these in mind if we go that way.
Old 04-11-2016, 08:58 PM   #9
Left Coast
Up on the grapevine take the 210 around LA....to San Bernadino, then east on I-10...
Old 04-12-2016, 12:10 PM   #10
Blog: RVroadtripper.com
hbillsmith's Avatar
#2 but do your overnight in Vicksburg MS its just a few miles before Jackson aand I did the No.2 to Ft Lauderdale last month. Stay at the Goodsam park at the America Casino in Vicksburg. If you can take a few hoursnthe next morn, drop trailer and do a drive thru at the National Confederate war museum. We spent 2 hrs there and its incredible. Its a huge battleground type park with many many huge memorial blds and statues. Its mostly just drive by if in a hurry or pull over and get out of car for closer look.
Maxxis 235/80/16E; AirBags w/AirLift 1 wireless compr; 4-Fold Tonneau; 6000# Dexters; mor/Ryde Rubber Pinbox & CRE3000 w/HD Wetbolts; Andersen UltimateII Aluminum 5erhitch on Reese Flipball w/Curt 4" offset ball; LCI Ground Control3 4pt+2pt Elec.Rear stabilizers; 3 Slidecovers; King Dishtailgater; 10ft. Portabote w/5hp Outboard; Dual A/C; Furrion48 Rearcam; Champion 3100 Inverter w/DIY Extended Run
hbillsmith is offline   Reply With Quote
california
