Old 05-21-2018, 12:59 PM   #1
Gassing up Diesel
Newby question: What is best strategy for gassing up my diesel while pulling my 36 ft 5th wheel? 13 ft high clearance.
I stopped at a truck stop only once, trucks were backed up 3 deep, some just sitting with motors running, is this the norm?
Yes, I know Gassing is wrong word, you know what I mean
coachrains is offline   Reply With Quote
Old 05-21-2018, 01:08 PM   #2
NMWildcat's Avatar
Truck stops are definitely easier to get in and out of while towing. We use them most of the time. Some are busy, some are not. We use Pilot/Flying J when we can, as most have specific RV lanes and we have an RV Plus card that allows fueling ( not gassing in the semi lanes using the card w/o having to go inside. Also has a small discount.
When no truckstops are in the area, we use Google Earth to look at potential stops to see if we can use them. We rarely get below half tank so we can be selective.
Scott and Liz - Southern NM
Old 05-21-2018, 01:17 PM   #3
Grammar Pedant
67L48's Avatar
First advice is to never gas up a diesel.
Secondly, I found that truck stops are the easiest. The pumps are parallel to the store front, there is space around the pumps for turning, and the stations themselves are easy to get in and out of. Big rigs are slow because many pay cash for the discount on the massive fuel bill -- which means they go inside, go to the bathroom, chat, stretch legs, pay ... all while the rig is outside blocking pumps. So, you just have to sort of wait it out.
Finally, when no truck stops are around, try to avoid stations that have pumps perpendicular to the store front. Either that, or you're going to be stuck with some hairy turns or waiting for the end position to open up.
Good luck.
TV: 2005 F150, 5.4L, Tow Package, 4WD
Current RV: 2018 Rockwood Mini Lite 2504S
67L48 is offline   Reply With Quote
Old 05-21-2018, 01:17 PM   #4
how do you get card?
Old 05-21-2018, 01:20 PM   #5
Georgia Rally Coordinator
aceinspp's Avatar
We also have the pilot/flying J card. You will find that the Flying J stations are more RV friendly and have special lane for you use whether it be gas or diesel. You can get a card through the Good Sam club which will get you discount for fuel. Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10 gear
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 67
Old 05-21-2018, 01:25 PM   #6
ramit315's Avatar
We always plan out routes to stop at Pilot/Flying J. We haven't had many issues with trucks stacking up and not moving. Most of them we have seen fuel then pull up if they need to go inside.
2017 Ford F-350 DRW
2017 Sandpiper 379FLOK
ramit315 is offline   Reply With Quote
Old 05-21-2018, 01:56 PM   #7
NMWildcat's Avatar
You can pick up an application at the store or go to the following website. This card is associated with Good Sam. Works well.
https://www.rvpluscard.com
Old 05-21-2018, 02:14 PM   #8
B47
Good luck.
Fortunately most big rig drivers do the right thing after fueling - that being pulling their rig forward to the line leaving room for the next rig to move up to the pump. Unfortunately,as you said,some,but not all,do leave their rig at the pump after fueling while tending to other non- fueling things.
Old 05-21-2018, 06:09 PM   #9
Or you could do what I did and install a 100 gallon extra fuel tank and stop after you stop for the night.
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is offline   Reply With Quote
Old 05-21-2018, 06:29 PM   #10
I installed a 50 gal Titan fuel tank. I can run an entire day then fuel up at night when Iím unhitched. That also allows more choice of stations not necessarily those closest to (and more expensive) the interstate.
TJA1 is offline   Reply With Quote
diesel, gas
