Old 04-17-2019, 12:11 PM   #11
Dr Travel
S.l.o.w. down
You are in too much of a rush. We spent a MONTH in Yellowstone and still did not get around to all we wanted to do. Right next to Yellowstone is Grand Teton NP - an astonishing place. If you "need" something to fill your time, then add that to your list. Colter Bay in Grand Teton has full hook-ups but you are likely too late to get a spot.
A day north of Yellowstone (not a full day) is Glacier National Park. Consider both depending on what you like to do. But rather than rushing around to "see more stuff" stay put longer and find out what these places are really like.
Homesick for places we've never been.
Fulltimers since 2014; still going strong in our RW Sig Ultralight Fiver. Have towed the Rockwood 27,000 miles with nary a hiccup. (Except for when participating in happy hours)
robsshots is offline   Reply With Quote
Old 04-17-2019, 12:14 PM   #12
Wind Cave National Park in S.D. Maybe drop down to Denver, Rocky Mt National Park, Colorado Springs and the Air Force Academy. Come back via St Louis?
AFDON is offline   Reply With Quote
Old 04-17-2019, 12:34 PM   #13
The only limit we're putting on this trip is the 8 week length. And the fact that we DON'T want to rush.
We'd rather sit and stay a while at worthy locations, as long as its not at the expense of rushing back east to get home. Nothing worse to ruin a trip than a high-pressure sprint at the end, with long tows. We'd like the WHOLE trip to go a leisurely pace... while taking no longer than 8 weeks.
Custer State Park is on our list to see the buffalo, and because it's so close to other sights (Mt Rushmore, Devils Tower), while also on the way to Yellowstone, so that was thinking regarding the route out.
Everything else, including duration of stay at each place, is flexible.
Interesting AND relaxing!
Toddavid is offline   Reply With Quote
Old 04-17-2019, 12:37 PM   #14
jkoenig24
Wink Too much
Eight weeks sounds like a lot of time but, in the RV world, it really isn't. It sounds like you want to see as much as possible which is something many (most?) new RVers try to do. It generally takes two ~ four years to get that urgency out of your system. You say it will take six days to drive out. That means it should take six days to drive back (maybe more). That alone uses up almost a quarter of your eight weeks. Driving like a fiend just to "get there" is likely to leave you tired (if not totally exhausted). My advice, cut back on your itinerary so that 1: you can stay safe (a tired driver is a dangerous driver) and 2: plan on staying a little longer at an interesting hub. Doing so will cut down on the time you spend setting up and tearing down your camp. SD Badlands area has LOTS to see and do and, it can generally be done with a modest drive from your camp. Allowing a little more time will also give you a "cushion" should the weather gods not smile upon you. The Moab, UT area is another area that would be a good hub. I talked with many campers who wished they could stay longer in a particular area. I can't remember speaking with anyone who said they stayed too long. If you're at least 62 years old, you (or anyone other senior in your group), qualifies for the National Parks Senior Pass. NOTE: although everyone in the SAME vehicle is admitted with that one Senior Pass, should you leave the park (shop, sightsee etc), that senior MUST be in your vehicle when you reenter the park! Otherwise, without the Senior Pass card holder present, you'll have to pay the going rate to get back in (Rangers check the ID of EVERY senior. DON'T try to use someone else's Senior Pass. It will be confiscated and you may be cited). If you can arrange to have a second driver, you will be able to cover more ground by switching off every two ~ three hours (at which time you can eat, use restrooms, refuel, stretch, etc. Regardless of how much you will be able to see, it will, at best, be only the tip of the iceberg. Concentrate on have a quality vacation over quantity. You'll always have next year to see more.
PS: I'm in my ninth year with over 100,000 mile traveled by RV. I've barely scratched the surface of all there is to see, do and explore.
jkoenig24 is offline   Reply With Quote
Old 04-17-2019, 12:38 PM   #15
Gsykora's Avatar
We did a similar trip last year. I'd stay a little longer in the Blackhills area. Rushmore & Crazyhorse monuments, drive the loop through Custer Park, maybe drive to Deadwood (if you want to see some cheesy motorcycle stuff). You can even drive the backroads and get back to the Badlands National Park. From there, we went to Devils Tower Monument - it'd definitely worth going there since you're in the area. We then went up to Glacier for several days. There is a lot to see in Glacier so I'd plan on 4+ days. Then we drove south to Yellowstone for 10 days. As others have said, it is very hard to see everything in Yellowstone in just a couple days. We took a different loop/area around the park each day and still missed lots. I fished one day, took a whitewater trip one day and we got rained out one day. We also drove down to the Grand Tetons National Park. Have to say, this was the biggest surprise of our trip. It was unbelievably beautiful - wish we had stayed a couple days there. Definitely get there.
There's so much to see in that part of the country, you really can't go wrong. Enjoy your trip.
George & Nancy, Allen, Texas
2015 F350 CC, DRW, LB, Platinum Edition
2018 Cedar Creek 36CK2
Gsykora is offline   Reply With Quote
Old 04-17-2019, 12:41 PM   #16
For the record, just to set the tone, we're not newbies at this.
I'm fully aware of the "eyes bigger than your stomach" phenomenon when it comes to travel.
We're about quality over quantity.
We've done tens of thousands of miles of RV towing up and down the east coast for years.
Besides a full year I spent in a 72 VW camper van traveling North America, this will be the first trip out west as a family.
Old 04-17-2019, 01:31 PM   #17
Here are a couple of possible stops to break up the trip;
The RV museum in Elkhart, IN.
The waterfalls in Sioux Falls, SD.
I would do the Badlands and Devils Tower as two day trips from the Black Hills.
From Grand Tetons NP, drop south to I-70 and stop at Arches NP and Canyonlands NP near Moab, UT. Following I-70 east you have Rocky Mountain NP (near Estes Park, CO) or the Airforce Academy and Pikes Peak in Colorado Springs, CO.
Once you start across the plains on I-70 there is the St Louis Arch, Indianapolis.
Catalina 333RETS
Keystone Outback 23RS
Silverado 2500HD
Goldwing 1800GL
Wilco is offline   Reply With Quote
Old 04-17-2019, 02:58 PM   #18
Again, thanks for the suggestions.
Looks like Grand Teton should be a mandatory destination.
What campgrounds should I seek at Yellowstone and at GT given my 5er size?
How about at Black Hills?
And I assume I should be booking now, even though the trip is a year away...
As long as you all indulge me, I will keep coming back to this thread for fine tuning as I dial in the trip.
Old 04-17-2019, 03:21 PM   #19
Gsykora's Avatar
We stayed at Grizzly RV Park and Cabins while at Yellowstone. A very nice park less than a block or two from the West Entrance to Yellowstone. If you stay outside of the Park, you have options for dining, groceries, setting up tours, etc. Not sure about Grand Tetons as we didn't stay there, but we did see Colter Bay RV village. Full hookups and looked pretty good.
Old 04-17-2019, 03:25 PM   #20
Gsykora's Avatar
There are dozens and dozens of RV parks in the Custer/Blackhills area. We stayed at Fort Welikit campground in Custer and really liked it. Although slightly smaller and a little tight, we were able to get our 40ft 5th wheel in with no problems. This campground is in the trees and seemed to be more scenic than lots of the other campgrounds in the area that look more like large parking lots.
