Old 01-05-2020, 10:26 PM   #1
DavidJ's Avatar
How to find gas stations that accommodate RVs
Hello, while cruising down the highway towards our destination, I needed gas. It made me wonder...
How do we find the gas station that is big enough for RVs?
I chose a QT and could not fit. What do big rig truckers do?
Is there a mysterious marker on the road? A trucker code I donít know about?
We have a Garmin RV 770. Maybe it can help!
Anyone care to share their secrets?
DavidJ is offline   Reply With Quote
Old 01-05-2020, 11:04 PM   #2
I currently own a diesel so I use trucker pumps in back. Flying J and Pilot have rv pumps in front of some stores. When I had gas trucks it could get tricky but I was always able to fit. My TT was 36í bumper to hitch
moose074 is offline   Reply With Quote
Old 01-05-2020, 11:04 PM   #3
GalsofEscape's Avatar
If you are traveling the interstates, the book "Next Exit" tells you what is at each exit and if the business is RV friendly. I also plan our stops and check out gas stations on Google maps ahead of time using the street view.
HTT: "EscapeII" 2016 Shamrock 23WS (current)
PUP: "Escape" 2010 Rockwood HW 277 (gone)
TV: "Bruce" 2011 Dodge Durango V8 Hemi Crew
Just us gals (me, Sis and our daughters)
We spend alot of money to go sit in the woods
GalsofEscape is online now   Reply With Quote
Old 01-05-2020, 11:08 PM   #4
SlowrideHD's Avatar
I use the Sync system on my Ford to locate diesel fuel stops and prices but there are lots of phone apps that will perform similar tasks (gas buddy). I can usually find a "Murphys" diesel pump near a Walmart, or a fuel pump at a Kroger or Costco. My last choice are the big truck stops because most require you to make a couple trips to the fuel desk, and their fuel is often $0.30 higher than other regular gas stations.
A lot depends on your skill and confidence in negotiating close quarters with your rig. I've never been in a spot that I couldn't navigate but I do avoid the little store parking lots that just have a couple pumps.
2016 F350 CC Dually Powerstroke 4x4
2014 Cedar Creek 34RLSA w/Level Up
2007 HD Ultra Classic 103
SlowrideHD is offline   Reply With Quote
Old 01-06-2020, 05:45 AM   #5
Any big truck stop like flying J, Loves, Speedway, pilots and such. I have the Rand McNally rv gps and it tells me where bigger gas stops are.
dodgemark is offline   Reply With Quote
Old 01-06-2020, 06:09 AM   #6
frank4711's Avatar
What size is your rig? I fueled at a QT near Atlanta and had plenty of room .... here in Fl Racetrack, WAWA and CircleK are big with lots of pumps and clearance ....
Frank & Cindy ... Rockwood 2888WS Ultra Lite 5th Wheel---2019 Ram 3500 Cummins 6.7 SRW 4x4 8' bed---Remi & Sage camp pups---TST 507 TPMS ... B&W Patriot 18K---3.73 axle ... Goodyear Endurance ... Predator 3500---48 days 2019--- *** Payload 4394 ***
frank4711 is offline   Reply With Quote
Old 01-06-2020, 06:40 AM   #7
Crusadernoob's Avatar
I actually like to find QT's, lots of room never had a problem.
2006 2500HD CCSB 2WD 2014 Crusader 285RET
Nights camped in 2013 - not enough!, 2014 37, 2015 40, 2016 39, 2017 38, 2018 36, 2019 37, 2020 4
Crusadernoob is offline   Reply With Quote
Old 01-06-2020, 08:23 AM   #8
When I had my gas truck I used Google Maps in advance to look for gas stations that would be suitable for me pulling a 30 foot trailer to get in and out. Now with a diesel truck I use an app called Trucker Path to locate service stations that have truck islands or are suitable for big rigs. So far it has served me very well.
Hank, Dianna and two fur babies Cody and Bella
2016 F250 PSD CC/SB
2018 Crusader 338RSK
Windjammin is online now   Reply With Quote
Old 01-06-2020, 08:31 AM   #9
KyDan's Avatar
I just try to hit the name brands- loves, Flying J etc. I burn gas so I have to fill up out front with all the cars unless they have the RV pumps on the side.
Try and get the end pump and don't forget to swing wide. In nearly 15 years I have pulled away without filling up less than 10 times and backed up to get out a few more.
Peace!
Dan & Rita D
Blue Ox WD hitch
Camping days 2010-53, 2011-47, 2012-41, 2013-41, 2014-31, 2015-40, 2016-44, 2017-63, 2018-75, 2019-32
Old 01-06-2020, 08:45 AM   #10
Gold Tee Box
Teetime's Avatar
Originally Posted by moose074 View Post
I currently own a diesel so I use trucker pumps in back. Flying J and Pilot have rv pumps in front of some stores. When I had gas trucks it could get tricky but I was always able to fit. My TT was 36’ bumper to hitch
I also went diesel a couple years ago, and use the trucker pumps with the big boys. We are about 56 feet total length TT and TV
Before that, I would refer to satellite view and street view on a map program, and plan my stops before leaving on the trip, so's not to go thru the frustration of pulling off the road and right back on because I could not get in or out of the pumps. Even some of the RV pumps can be difficult.
Success is hiring someone to mow your lawn so you can play golf for exercise.
2018 GMC 2500 Duramax Denali
2018 Coachman Freedom Express 287BHDS
60+ campgrounds/400+ nights, 20K+ Miles towing since 2015
Teetime is offline   Reply With Quote
Old 01-06-2020, 09:02 AM   #11
TowPro's Avatar
I have only once had a problem with fuel stops, that was coming around Washington and the quantico base area. But it was my own fault, the truck holds over 4-6 hours worth of fuel and I passed many stations before I got to the point I needed fuel.
you need to be willing to stop and fill up a tank that ls already 1/2 full.
I usually plan out my routes using mapping products (garmin Basecamp) on my computer and work out fuel stop areas. Than using Google Maps you can view street level to check out each station to see if its got room or not, than Mark that station as a waypoint on your route in GPS. I don't worry about 10c per gallon difference, if one is easy to get into its worth $2:00 more to me to get in and out.
Something else I have found works best for me is when doing multi day trips plan out your morning starts so you get fuel first thing at a place that also fast food restaurant for breakfast
If this is a route you will be taking in future (weeks/months/year) and you see a good fuel station on your way, take notes and apply them to your GPS as Waypoint.
What makes filling stations hard is the people who leave cars/trucks/RV's on the pump while they go in and order food from the restaurant.
2019 Forest River Forester MBS 2401R
TowPro is online now   Reply With Quote
Old 01-06-2020, 09:09 AM   #12
X2
The bigger name brands mentioned will accommodate and many have R/V lanes but you may have to wait your turn for an end pump. If you can drive and back up, you shouldn't have an issue anywhere.
Some complain Flying J and Pilot are too expensive but with the Good Sam discount, I've found on the East Coast, the prices are comparable to any other fuel.
I left without fueling at a Mom & Pop Exxon a few years ago but that's the only time in the last 20 years I can recall doing so. I hit the next exit and got right in.
It might be a bit tough while driving but I'll often scope out unknown fuel stations on Google Maps the night before. With the satellite view you know exactly what you are getting.
One last thing... do not wait until you are running on fumes to fill up. If you get to a fuel station you can't get in, at least you'll have enough to go elsewhere if you still have some fuel.
As a last resort, drop the rig in a parking lot and go fill up but you should NEVER have to do that!
Days Camped: '17=30 '18=51 '19=58 '20=14
Old 01-06-2020, 09:53 AM   #13
Jim34RL's Avatar
If you have a gas truck you can always un-hook and fill up the truck and than re-attach the trailer to the truck. Until you need to do this all over again!
I have only tow a small 5er on two trips with a gas truck. After the last trip, about 350 miles long, I told my wife we either sell the camper or buy a diesel tow vehicle. Will we purchased a 2008, Dodge Mega Cab, 6.7L Cummins diesel truck and never look back! If I ever purchase a new tow vehicle again it will be another Ram truck with the 6.7L Cummins engine.
Once you have tow with a diesel truck you will never tow with anything else.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 135K+miles
Old 01-06-2020, 09:55 AM   #14
LOL... didn't take long to turn into a gas -vs- diesel debate!
Geez!
Old 01-06-2020, 10:25 AM   #15
frank4711's Avatar
X2
Yep ..... wait for end spot or just pull in like you own it ... after 25 years pulling 28' lawn trailer you get use to seeing were to go so you can get thru and out ... wait if you have to and don't be in a hurry your camping .... I get my diesel out front with the rest of the gassers
Old 01-06-2020, 10:41 AM   #16
Use your mapping software and calculate about where you will need fuel. Then use the satellite view to see if there will be access for your rig. I have found Flying J and TA to be the best bet for RV lanes.
I have found using RV Trip Wizard to work quite well because you can put in information about your vehicle fuel capacity and expected mileage and it will put alerts on your route for where you need to be looking for fuel. If you put a fuel stop as a waypoint go the info for that point and be sure to note that you filled up and it will calculate your next fuel stop. It’s a pretty hand thing to have when we are in a Motor Home towing a car hauler.
2020 Coachmen Mirada Select 37RB
DougW is offline   Reply With Quote
Old 01-06-2020, 11:09 AM   #17
dbarr's Avatar
I watch my gauge. When my 36 gallon tank says I have 6 gallons left I get off the highway and fill up at the nearest station.
LOL... you asked how truckers do it.
'15 F150 Ecoboost Maxtow Scab '19 Keystone Laredo 225MK
Days camped 2019-36, 2018-24, 2017-46, 2016 -56, 2015-33,
2014-47,
Years camping....54
dbarr is online now   Reply With Quote
Old 01-06-2020, 02:32 PM   #18
CaptnJohn's Avatar
When I pulled with a gasser Flying J was always the preferred gas stop and used the RV lanes. Usually quicker and always safer. If concerned about pennies sell it all and buy a Prius and a tent.
For a long time my daily driver/TV is a diesel. I use the truck lanes when pulling. Easy, quick, and safer.
2019 Montana 3761 FL
2019 F350 6.7 4X4 LB Dually
Edgewater 205 EX 150 Yamaha
Old 01-06-2020, 02:36 PM   #19
I use Love’s truck plaza front pump for my diesel fuel. There’s always plenty of room to maneuver around with usually no waiting. I’m pulling a 38’ fifth wheel and never had any problems in eleven years. Plenty of pumps for gassers.
bajamike1 is offline   Reply With Quote
Old 01-06-2020, 02:44 PM   #20
RudysWorld's Avatar
I have a gas rig and use the pilot flying j app. It will tell you what locations have RV lanes. Sign up for their RV club and you get an id card that gives 5 cents off a gallon. Not a credit card a id card only. Good Luck!
Rudy - 10 year old long haired dachshund, RIP
2011 Georgetown 350TS
2013 Chevrolet Equinox toad
RudysWorld is offline   Reply With Quote
gas
