Old 02-21-2016, 11:47 AM   #11
asquared's Avatar
Originally Posted by RFLLambert View Post
I bought a Garmin RV 760 GPS last year. You can input your RV data and it will warn you. I am really satisfied, at least once it saved me to get into trouble.
X2 on Garmin rv 760LMT. You can choose car or RV when using it. You input your rv dimensions and weight. It has traffic alerts too. I've had good luck with it so far. My only downside was the 7" size is bigger than I like.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 02-21-2016, 11:54 AM   #12
Originally Posted by Jim34RL View Post
The Rand McNally RV GPS unit will also route you around low clearances and some tunnels that restrict propane. In the Route folder you can pick your preference such as no interstates, toll roads, U-turns, dirt roads and other items. Under the RV preferences you state the length of the RV including tow vehicle, weight, height, number of propane tanks and size. with this information the program will route you according to you preferences. You can also set the speed that you want to tow at and the unit will tell you if you exceed your set tow speed or above the speed limit.
X2. We have the Rand McNally RV7715 and it keeps you out of trouble well, as long as you set your parameters and put your info in correctly. If you are under 13'6" ,which you likely are you will have little trouble. Just watch
Bridge signs and especially the corner gusset heights on covered wooden or steel bridges. We two preferred roads less travelled.
Have fun.
Floyd & Carolyn
2012 F150 S/crew 4X4 6.2L 6Spd Tow Max Firestone airbags. 2011 28RKS Wildcat. Yamaha 3000iseb Gen.
2013 22 nights.2014 57 nights.2015 116 nights
2016. 96 nights 2017 72 nights.
Filterman is offline   Reply With Quote
Old 02-21-2016, 11:57 AM   #13
I use the Rand McNally gps but I also lay out my route then follow the route on Google Earth. When I see a bridge I go to street level and look at the height sign if it is a low bridge.
bplantcjf is offline   Reply With Quote
Old 02-21-2016, 12:40 PM   #14
Waze is a good app for your smart phone or tablet, you'll need web access though
Jim & Pam
Ram 2500, Crew Cab
2014 Hemisphere 327res
JP Camper is offline   Reply With Quote
Old 02-21-2016, 01:30 PM   #15
camaraderie's Avatar
Cheap and good is the Co Pilot app for android or i phone that lets you program in your preferences including height restrictions. Does NOT need a phone signal to work like GoogleMaps as the maps are stored in the phone. Full version with voice & traffic is under ten bucks....and there are several lesser options all the way down to free. See it here: https://copilotgps.com/us/
________
Cam
2015 Georgetown 280DS
2014 Vespa LX150 2014 StellaAuto 125
camaraderie is offline   Reply With Quote
Old 02-21-2016, 01:36 PM   #16
DITTO.....
Jon A is offline   Reply With Quote
Old 02-21-2016, 02:44 PM   #17
Oaklevel's Avatar
I assume that you need a smart phone for these amps ????????
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
Old 02-21-2016, 02:50 PM   #18
Ford Idaho's Avatar
App?
I use a MOTO X phone it is only kinna smart, but yes.
Old 02-21-2016, 03:05 PM   #19
CoPilot does NOT require a phone. You can use it on an android based tablet (since GPS is built in). I have a copy on my 10" Samsung Tab which is a bit much for the dashboard (using the phone there) but excellent for my navigator in the right hand seat.
________
Cam
Old 02-21-2016, 03:12 PM   #20
Oaklevel's Avatar
Tablet? mine requires a pencil is there another type? Android thought that was in a sci fi movie guess I better get up to the times............ Sorry........... have none of those things I could check my Beta tapes to see if I have an Android alien in them........ I don't guess anyone still uses paper maps like I do any more either. .............
1966 Mustang GT
1986 Mustang SVO
travel
