Old 10-10-2013, 07:56 PM   #11
AquaMan's Avatar
My curt rails didn't require drilling of the frame also, but with a newer GM the frame is boxed and the bolts have to be fished through the frame. Then once the frame bracket is installed the the rail bolts need bolted through bed, of which 2 are on top of the fuel tank, which is nearly impossible to reach. Oh, and don't forget to try and hold the spacer up while trying thread the nut on while nearly standing on your head. Uh oh, forgot to weight down the bolt so it wouldn't raise up while trying to put but on. Now you see the trend for the next 10 bolts. Not sure I would pay $300 for the install though, $125 is a no brainer.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 38
Old 10-10-2013, 08:13 PM   #12
Aca651's Avatar
Thanks for all the input. I shot my load on the camper and if I can save some dough installing the hitch myself I'm all in. Guys at work are confident we can knock it out in a Saturday afternoon after shop closes. So as long as I've got some help I think it's doable.
Trying to talk the Mrs. Into a February trip to SC when the kids school break comes up. I'm trying to come up with a workable scenario to get this new rig working!
Thanks for all the thoughts and input. It's appreciated.
Andy
Aca651 is offline   Reply With Quote
Old 10-10-2013, 11:03 PM   #13
Ford Idaho's Avatar
I let the dealer install my PullRite because the 4 huge holes in the floor of the bed needed to match the ones in the rails for the 4 posts.
Dropped the truck off and then went shopping, did our walk thru hooked up the trailer and drove home.
Old 10-11-2013, 06:50 AM   #14
Camper Less Camping
Cajun Po-Boy's Avatar
Andy
If you can find someone to install the hitch between $150-200, that's nothing compared to your fuel expenses when pulling the fifth wheel...just to put things in perspective
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
Old 10-11-2013, 08:12 AM   #15
5erDriver's Avatar
You can do it I'm sure. I installed mine with a friend in about 2 1/2 hours. It definitely helps to have a second pair of hands, and eyes. It's not rocket science. Just measure carefully and as mentioned have fresh drill bits.
Been to the Rockland show many times. Did you buy from Scott's?
2013 Sandpiper 365SAQ
2008 Ford F350 Super Duty
6.4L Powerstroke Long Bed CC
5erDriver is offline   Reply With Quote
Old 10-11-2013, 12:00 PM   #16
Great Horned Owl's Avatar
How difficult a job it will be is highly dependent on which rails and installation kit you buy. The "universal" kits will require that you drill some large holes into the truck frame rails. You probably want to avoid that. The "custom" kits will bolt to existing holes in the truck frame rails.
Depending on what truck you have and which custom kit you get, you may need to drop the fuel tank and a heat shield in order to bolt the brackets to the inboard side of the frame rails. For some trucks, Reese makes an installation kit with brackets that bolt to the outboard side of the frame rails. The only thing in the way will be the spare tire. If available for your truck, that is the way to go.
Trailer hitch, hitches and bike rack (800)298-8924 usually has the best prices on the hitches. Their web site also has some videos of installations being done. You will need a rather hefty torque wrench.
I was 71 years old when I installed mine, and I am nit a mechanic. You can do it.
Joel
2011 Silverado 2500HD Duramax, 4x4, crew cab, long bed
Palomino Puma 253-FBS, 27' 5th wheel
1994 19' Class B on Chevy chassis
Great Horned Owl is offline   Reply With Quote
Old 10-12-2013, 05:56 PM   #17
Aca651's Avatar
Originally Posted by 5erDriver View Post
You can do it I'm sure. I installed mine with a friend in about 2 1/2 hours. It definitely helps to have a second pair of hands, and eyes. It's not rocket science. Just measure carefully and as mentioned have fresh drill bits. Been to the Rockland show many times. Did you buy from Scott's?
I did not buy from Scott's dealer I used is escape rv. Out of jersey the sales people. Was not at all impressed with the dealership but the people who run it were top notch You can always find a better deal if you keep looking I'm very comfortable with the price I got and never once felt pressured.
I live in Westchester and it's not a terrible ride to get there.
Thanks for your thoughts on the hitch install.
Andy
