Old 08-06-2017, 06:52 AM   #1
gam
1st time out
Hi all! I have trailer plugged in to load fridge/freezer, should I turn on l. Propane for 3 hr drive or just leave it off? Thanks
gam is offline   Reply With Quote
Old 08-06-2017, 06:55 AM   #2
crunchman12001's Avatar
Set the button to Auto and it will automatically go to propane when unplugged and switch back to AC power when plugged back in.
Yes, use propane when traveling.
2015 F-250 FX4
Old 08-06-2017, 06:56 AM   #3
geeman53's Avatar
Welcome from SW Ohio ,enjoy your TT .Turn propane on and refer on auto. Good luck !
2016 sunseeker 2250slec
1988 Jayco p.u.,Coleman Plantation p.u.,1989 Jayco class c, Coachman TT,1995 Little Eddie fthwheel,2007 Heartland Sundance 2500 lS fthwheel
geeman53 is offline   Reply With Quote
Old 08-06-2017, 11:11 AM   #4
gam
Thank you for your replies I appreciate your help
Old 08-07-2017, 09:44 AM   #5
Chief T's Avatar
Aren't there safety concerns if he goes to a gas station with an open flame?
2012 GMC Sierra 1500 SLT Z71 6.2l aka "Luci"
2020 Grand Design Imagine XLS 22 MLE aka "Desi"
Past: 2017 Prime Time Tracer Air 206
Days camped 2021: 19
Days camped 2020: 18
Days camped 2019: 17
Chief T is offline   Reply With Quote
Old 08-07-2017, 09:57 AM   #6
Flybob's Avatar
You may want to unplug and check to see if it will auto start on propane if you plan to run on propane. As this is a new unit, there may still be air in the lines which can cause it to go into safe mode after several tries at lighting. Once you are sure it lights and stays lit, then you can use auto. Just be aware you have propane on.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 08-07-2017, 10:21 AM   #7
Brother Les's Avatar
this may sound fundamental but yes have the propane at the ready to come on. If plugged into land line 110v, at the frig, push 'Auto' button, then open propane tank that you will use, turn on one burner on the stove to bleed air out of propane line. Light stove burner to the point that is burns clean and has no air in line, shut off stove burner..... Now, leave as is. When you unplug the shore line, the propane will 'auto' and change over and light the propane to the fridge. 3hours or three months, it is fine to use the propane on the RV.
Brother Les
Old 08-09-2017, 07:55 AM   #8
Ilovetocamp's Avatar
I'm learning too. Thank you
Ilovetocamp is offline   Reply With Quote
